Results 1 to 8 of 8
    Reputation: photosheikh's Avatar
    Using a washer to create space for rotor - Acceptable?
    Hi,
    Just wanted some views on what I have done to make some clearance between my rotor mount and caliper mount. As you can see I have added a pedal washer and it fits perfect as a spacer. Is this acceptable in terms of safety.
    Thanks,
    tBike
    bt
    bt is offline
    Nov 2007
    no not alright
    Reputation: dirtyjack's Avatar
    You can see in your first photo that you've replaced a knurled surface with a smooth one. Not a good idea.
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Quote Originally Posted by dirtyjack View Post
    ^^^^This.
    Figure out a way to move your caliper into better alignment at the caliper mount rather than using a spacer to move the wheel inward/fork outward at the axle.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Using these is the correct way;
    Hope Rotor Spacer | Buy Online | ChainReactionCycles.com
    ako
    ako is offline
    Oct 2012
    If you cannot move the calliper you could look at skimming the brake mounting face of the hub. This would need to be done with the wheel stripped down and the hub in a lathe.
    You would only want to remove the thickness of the washer. You would need to check the brake mounting bolts still have sufficient thread engagement into the hub.
    This would most likely need to be done in an engineering workshop rather than a LBS.
    On wuss patrol
    Quote Originally Posted by AZ.MTNS View Post
    Looking at the physics of his situation, I think this type of spacer would move the rotor the opposite direction of where it needs to be. Cool idea otherwise.
    ako
    ako is offline
    Oct 2012
    A similar disc with 2x6 holes could do the same trick, but the disc would need to have the centre hole opened up (to fit over the hub) and have enough meat to have 6 holes drilled on a larger PCD.
