Results 1 to 2 of 2
    Reputation: Sbrown's Avatar
    Upgade Mechanical Disc to Hydraulic Disc Brake
    Can you replace Avid bb5 brakes with the Hayes Stroker Carbon? Will the cables fit in the guides? I am running a Gary Fisher Cobia in the following setup and want to upgrade the brakeset to Hydraulic Disc Brakes.
    2009 Gary Fisher Cobia
    Frame Fisher Platinum Series ZR9000 aluminum
    Fork RockShox Tora Race Solo Air 29, 80mm travel,
    (custom G2 Geometry 51mm offset crown, air spring, motion control damping & lockout)
    Rims/Wheels Bontrager Ranger Disc
    Hubs Shimano M475
    Tires Bontrager XDX, 29 x 2.1
    Crankset Race Face Dues XC, 175mm
    Bottom Bracket Race Face BB X-TYPE XC/AM
    Chainwheel Race Face 22,32,44
    Front Derailleur SRAM X-9 22 tooth to 44 tooth
    Rear Derailleur SRAM X-9 Long Cage
    Rear Cogs SRAM PG950 11-34T, 9spd
    Shifters SRAM X.9, Trigger Shifter Set
    Handlebars Race Face Deus XC Low Rise, 660mm width, 31.8 diam.
    Stem Thompson Elite X4, part #SM-E133,
    Headset Cane Creek VP-A42E
    Brake Levers Avid FR-5
    Brakes Avid BB5, mechanical disc, 160mm Roundagon 6-bolt rotors
    Pedals Ritchey Logic Pro V4 Mtn w/ Cleats Clipless Pedals
    Saddle Bontrager Race
    Seat Post Race Face Deus XC
    The hose will fit in the cable housing guides.
