Results 1 to 21 of 21
    Update on crappy Avid XX brakes
    Now Avid is saying they had a run of bad hoses and are sending my LBS
    replacement hoses.And even including a free new chain for my time!
    That's after my LBS telling them I have no confidence in there product and I want them to
    give the LBS credit for what is an inferior POS brake set up.
    I'll continue to post as the saga of the XX brakes continue.
    If you want great lightweight high end discs go get Formula R-1s.
    Thank you for your concern and kind thoughts my many MTBR brake fans.
    LS
    Reputation: dblvanos's Avatar
    Link to original thread?
    Reputation: dirtyjack's Avatar
    A friend just went through certification by SRAM. He was told that the XX's require bleeding/fluid flush EVERY 6 MONTHS, due to the fluid wanting to absorb air or water!!!
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Quote Originally Posted by dirtyjack
    All brake fluid does this.....including your car. Do you flush your car's brake system every 6 months?
    Reputation: knl2stl's Avatar
    Jan 2011
    What about mineral oil, e.g., as found in Magura?
    Jun 2010
    I do every two years on my vehicles.Brake fluid absorbs at least 10% moisture in that time and your car has a fluid reservoir several hundred times larger than your bike. Now all we need are speedbleeders like I put on all my four wheeled vehicles, it makes changing brake fluid a one man job that takes twenty minutes.My other pet peeve is people using brake fluid from a container that was already opened.I feel brake fluid,recipe for contamination.
    Reputation: timroz's Avatar
    Feb 2007
    Quote Originally Posted by Lickety Split
    LS
    They have free beer THERE.
    THEY'RE giving away free beer.
    I've been to THIER house and they have free beer.
    OK?
    Learn some english.
    Quote Originally Posted by timroz
    I've been to THEIR house and they have free beer.
    Learn some english.
    ftfy
    OK?
    Learn some english.
    There goes a Dbag named Tim.
    Tim the internet Dbag lives their.
    Now here's a shiny bottle cap.
    Go sit in the corner and amuse yourself.
    LS
    Reputation: madsedan's Avatar
    Aug 2010
    "I've been to THIER house and they have free beer."
    Classic, correcting someone's grammar with a spelling mistake, thanks for the LOL on firday morning!
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
    MTBR Member
    Reputation: ncfisherman's Avatar
    Quote Originally Posted by madsedan
    Ahhh...beat me to it! And he misspelled "their" in all caps, no less.
    Tool
    Reputation: Pedalphile's Avatar
    Quote Originally Posted by ncfisherman
    And he mispelled "their" in all caps, no less.
    That's probably what thwarted his spellchecker.
    LS - how 'bout a link to the original thread?? Your comments are completely out of context without it.
    It's not clear whether Avid has been stepping up to the plate trying to fix your issues or not. It seems they are, yet you're still bashing them.
    Did you keep the free chain or give it back due to low confidence in the product?
    I have no experience with XX brakes, but I have Juicy Ultimates on one bike and XO's on another, and both do exactly what they're supposed to do.
    -Pete
    I can barely get my mouth around it.
    Jan 2005
    [QUOTE=the mayor]All brake fluid does this.....including your car. Do you flush your car's brake system every 6 months?[/QUOTE
    Completely incorrect. DOT 5 does not absorb air / moisture. It's silicone based.
    Reputation: Acero853's Avatar
    Feb 2010
    Quote Originally Posted by Pedalphile
    -Pete
    I think this is the first thread: really informative. Puts lots in context.
    Third time the charm for Avid XX brakes??
    Barry
    Yeah well, that's just, ya' know, like, your opinion, man.
    _____________________________
    the cycling librarian(blog)
    Tool
    Quote Originally Posted by Acero853
    Barry
    I wouldn't have linked to that either.
    Good luck, LS. Hopefully the new hose does it for you. You have to admit that Avid is excellent with warranty issues.
    Do, however, give some thought to why the LBS was willing to send you home with a brand new bike they absolutely knew wasn't working properly, and with such a vital part of the bike with respect to your safety.
    [QUOTE=Bikeeveryday]
    Quote Originally Posted by the mayor
    AHH....Yeah DOT 5 is silicone based.....However, SRAM/Avid uses DOT 5.1. 5.1 is glycol based just like DOT 3 or 4. NO bike disc brake uses DOT 5 that I am aware of.
    However, Definitely not defending SRAM. They have more documented issues with their brakes than anyone else. Gobbling noises,bad seals,vibration issues...blah blah blah. I really think they have to figure out the real issues and fix em.
    Tool
    Quote Originally Posted by Bikeeveryday
    Seems to me the online complaints per brand regarding brakes is fairly proportional to the number of units in the market per brand. You have sumin' that indicates otherwise?
    Jan 2005
    yeah
    Honestly, I have avid brakes on both of my bikes and I don't have any issues. Try changing your rotors. The warbling noise you hear a lot of times comes from the rotor arms passing the surface of the pad. I mean if you think about it's a brake. It's metal getting pressed up against metal, it's normal for some noise to occur.
    I was just pointing out that DOT 5 being silicone based didn't absorb moisture/ air. I know avid uses DOT 3/4/5.1, which certainly does absorb all that chit.
    Apr 2005
    My three bikes are full Sram XX equiped and as far as brakes, they have been working excellent for the past 8 months... the only issue was with the Sram XX World Cup SID, but like Pedalphile said Sram have one of the best costumer service out there, got the replacement part within 3 days and also some free stuff....
    Great company..
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Yep, that's essentially racing fluid....my Audi quattro comes with it stock.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    d-OH!!!
