Results 1 to 10 of 10
    Mar 2015
    Unusual hydraulic fails.
    I've recently purchased a used 9.7 superfly and it worked well for a couple of weeks but after that the hydraulic brakes failed couple of times in a weeks time. I don't understand how it happened? I've read about hydraulic pumps fail when overheating happens, read it in hydraulic systems blog, but I don't understand how it is so frequently happening in my bike? I'm just learning my lessons and yeah do some stunts once in a while, but I don't think I've overstrained them. Is it the way I ride? or else the bike reviews are really good especially the brakes. Am I missing something here?
    Nov 2012
    Fail how? Usually the seals just wear out, you could have taper bore avid brakes which are known to trap air pockets.
    They both started failing at the same time? That seems statistically unlikely, but possible. Did you crash?
    Quote Originally Posted by NOahPark View Post
    ........ Am I missing something here?
    Yes, something is missing.....like details of the failure. Smh
    Reputation: DethWshBkr's Avatar
    Quote Originally Posted by the-one1 View Post
    I can't seem to get my lawnmower to work, what is wrong?
    Nov 2012
    Quote Originally Posted by DethWshBkr View Post
    Did you put gas in it...
    Magically Delicious
    Reputation: Cleared2land's Avatar
    I put fresh antifreeze in my radiator and the transmission went out? What happened?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    I have put gas in it, but it just keeps stopping again. I have seen jet engines shut off after a bird hits it, I can't understand why it happens so often. I guess I need to quit mowing up the hills.
    Quote Originally Posted by Cleared2land View Post
    Was it below freezing? You should have put the antifreeze in the transmission! Sheesh!
    Magically Delicious
    Oh, I understand now...
  1. Mountain biking fails
    By AshevilleMtBiker in forum General Discussion
    Last Post: 03-04-2015, 07:48 PM
  2. What to use if 2Bliss tape fails?
    By Alias530 in forum Specialized
    Last Post: 04-02-2014, 09:38 AM
  3. Craigslist never fails to amaze me
    By Javelina in forum Arizona
    Last Post: 04-13-2013, 12:16 PM
  4. Wedding Announcement Fails
    By monogod in forum Off Camber (off topic)
    Last Post: 03-18-2013, 08:22 PM
  5. Petri Amendment FAILS
    By UncleTrail in forum Colorado - Front Range
    Last Post: 02-02-2012, 07:21 PM
