Results 1 to 3 of 3
    Two wheels/rotors with one set of XT Ice Tech brakes/calipers?
    Ok, so if I get an extra set of wheels for my bike, say with different tires, and I swap the wheels from time to time, is there any concern regarding rotors? I have 160 rear and 180 front ice tech rotors on my main set of wheels. Do I need to have Ice Tech rotors on the second set so that the calipers and pads match up easiest, and/or so the pad wear is kept similar?
    El CicloPath!!!!!!!
    Nov 2012
    Quote Originally Posted by morkys View Post
    I think the biggest concern regarding swapping our wheels with different discs is that you may have to do a new bedding procedure for the pads and disc. But I've used different discs with the same pads and they have all worked well after a few stops.
  1. BB7 calipers with rt81 ice tech rotors
    By hardup in forum Brake Time
    Last Post: 06-03-2013, 04:29 PM
  2. Replies: 1
    Last Post: 03-22-2013, 12:09 AM
  3. Replies: 0
    Last Post: 01-01-2013, 08:06 PM
  4. Replies: 6
    Last Post: 09-13-2012, 09:11 PM
