Results 1 to 6 of 6
    Jun 2013
    Trying to find some big hydraulic brakes 200mm+. Can anyone help find some?
    Basically what the title says. I'm looking to go all out on some brakes and I work on cars a lot so bleeding brakes is no problem. Anyone know what the best choices are? I've tried a lot of googling and haven't found much. Thanks!
    Apr 2005
    Shimano XT brakes are available in 203mm. Most manufacturers make a rotor at or around 200mm. I'm not aware of anything bigger, but the 203mm XT should be as much as anybody needs.
    May 2013
    If you want all out, get Hope V4 with 203mm rotors. Next wouls be Shimano Saint.
    Reputation: Shalom's Avatar
    Nov 2008
    Hope TEch Evo V4 brakes with 203mm rotors. However, check to make sure that your fork is rated for rotors that big. Otherwise, fork failure could well be in your future.
    Jun 2013
    Interesting I didn't know I had to worry about fork failure. I'll look into that and thanks for these suggestions!
    Nov 2008
    Probably not such a big issue if your fork is rated to 200mm and you want to run a 203 mm rotor.
    However, if it is rated to 180 and you run a 200, then issues *could* occur.
  1. Brakes - 200mm for IS mounts - Cheapest VS Low Maintenance
    By Kos F in forum Downhill - Freeride
    Last Post: 05-08-2013, 03:44 AM
  2. help me find a dj
    By Dan GSR in forum Urban/DJ/Park
    Last Post: 12-21-2012, 07:00 PM
  3. Help me find my pad.
    By bghtn in forum Brake Time
    Last Post: 10-27-2012, 04:38 AM
  4. HELP ME (and others) find a job!
    By socalMX in forum Off Camber (off topic)
    Last Post: 03-16-2012, 04:11 PM
  5. What do you think of this CL find...
    By massahwahl in forum Beginner's Corner
    Last Post: 03-24-2011, 02:16 PM
