Results 1 to 19 of 19
    Reputation: rickcin's Avatar
    TRP Mini V squeal?
    Had my canti brakes replaced with these mini v's and I love them, great brakes!
    The front set starting squeaking really bad and appear to be properly adjusted, any suggestions?
    They are good for alerting pedestrians walking in front of me!
    Plays with tools
    Reputation: customfab's Avatar
    How much toe are you running on the pads? Try cleaning your rims with scotch bright and alcohol to make sure they are not contaminated. Swapping pad compounds might be worth a try as well.
    Quote Originally Posted by customfab View Post
    Thanks, I will first try cleaning the rims as you have recommended. Not sure about the toe on the pads but that will be the next step if necessary.
    Thanks for your input!
    Reputation: limba's Avatar
    I think they come with cheap pads? Try some Kool Stop salmons if nothing else seems to work.
    TRP's really come with cheap pads??
    Plays with tools
    Quote Originally Posted by rickcin View Post
    They aren't anything special.
    Cheap was the wrong word. They're fine, average pads. Koolstop are absolutely an upgrade. Swiss Stop also get good reviews but I haven't tried them.
    Quote Originally Posted by limba View Post
    Need to determine if Koolstop pads only will fit the TRP C9's or do I need to change the pad with the mounting backer portion?
    Plays with tools
    TRP uses a shimano compatible pad. The stock holders will work fine.
    Thanks!!
    Guess what, your advice worked, scotch pad and alcohol did the trick and I am wondering if this is normal and will continue to happen?
    At any rate I really appreciate your advice!
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    Get some Yokozuna salmon inserts. Great stopping power/feel, and the quietest pads I've ever used.
    GRAVELBIKE.COM - ride everything
    Quote Originally Posted by MileHighMark View Post
    Will do, just need to figure out how to swap out the pads. They current pads in the TRP's just slide out and the new ones in?
    Ride Everything
    Depends on the model. Some have a small allen fitting that you loosen to remove the insert, and some have a cotter pin. If you post a pic, folks could confirm/recommend the correct insert.
    I just took a look at my bike and you are a smart guy, the pad has a set screw through the back. So now my next question is how difficult to readjust the brakes due to the new pad?
    Obviously no barrel adjuster on the cable on these mini v's, TRP CX 9's.
    Ride Everything
    The Yokozuna inserts may be a little thinner. If there's no barrel adjuster, you'll need to take up some slack via the cable itself.
    Okay, I think I have it figured out, with your hep of course! The set screw allows the pads to be removed, the brake space adjustment to the rim is accomplished by changing the cable length with the lock screw and the spring adjuster set screw will coordinate the pad motion against the rim.
    I think that is it??
    Thanks again!
    Ride Everything
    Thanks again!
    Basically, yes.
    Feb 2013
    I have the same problem with TRP, have used swiss pads, kool stop adjusment same squeaking
  1. BMX mini or micro mini?
    By paulbu in forum Families and Riding with Kids
    Last Post: 05-23-2017, 03:07 AM
  2. Brake squeal
    By lagocza in forum Brake Time
    Last Post: 06-07-2013, 06:02 AM
  3. mini z not mini me and other hobby pics
    By singlesprocket in forum Off Camber (off topic)
    Last Post: 04-13-2013, 10:52 AM
  4. Magura MT-8 squeal
    By spookyload in forum Brake Time
    Last Post: 08-08-2012, 05:08 AM
  5. BB7 Squeal
    By Scottyc in forum Brake Time
    Last Post: 07-24-2011, 09:49 PM
