Results 1 to 11 of 11
    Tricks to cut hydraulic hose?
    I'm swapping brake lines on my elixir R's. I just bought some Jagwire Hyflow Universal lines and a quick fit kit. I'm a noob to this...what's the best way to make a clean cut on the brake hose without crimping the lines?
    Take a razor blade ( a sharp one) and slowly roll the line under the blade gently while gently pushing down. The blade will cut through cleanly.
    Reputation: evenslower's Avatar
    I've used my cable cutters and cleaned the end up a little with no issues. Small tip, push the hose firmly into the reservoir body while tightening the compression nut and don't stop pushing until you're done tightening. If you don't the hose can back out a little and cause the compression fitting to move too far to the end of the hose and you'll have a leak.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Best tool is the one designed for the job . . . but whatever you use, it has to have good leverage and be SHARP. You cant to cut through the line quick, not crush it. If you crush the interior hose, your barbs might not fit snug anymore.
    LightJunction.com
    Reputation: lightjunction's Avatar
    Your LBS should have a hydraulic line cutter. I can't imagine they'd charge you much, if anything, to cut one line. You could try the razor blade method, but it's always best to use the right tool for the job.
    We sell quality bike headlights and flashlights.
    www.LightJunction.com
    whatever makes a flat clean cut. I've used razors, box knifes, Japanese kitchen knives. All work if they are sharp and steady.
    ______________________________
    "If it ain't moto, it's worthless"
    I'm Slow
    Reputation: paulrb02's Avatar
    Buy this little guy: http://www.amazon.com/Sunlite-Hydrau.../dp/B0037N6A4W
    It works great and its cheap, its what I use.
    RideSAMBA.com Mountain Biking in South Alabama.
    Reputation: shapirus's Avatar
    I always used a pair of decent cable cutters to cut braided hose (Goodridge). Are there better methods? Dremel, anyone?
    I have used a tubing cutter from Home Depot to cut hydraulic brake lines multiple times and it makes very clean and straight cuts effortlessly. It's made by Rigid (RIDGID PC-1250 Pipe Cutter, Store SKU # 483594). I found it in the plumbing section for less than $18. There is another one similar for around $12 but I liked the way the Rigid one looked.
    A sharp razor blade, steady hand and a straight surface is all you need to cut the lines. I just trimmed the hoses on my elixirs to fit and the razors cut through them clean and straight.
    I got the velcros
    Another razor blade advocate here.
    Tip: cut several practice cuts a couple inches past (longer) than where you plan to actually cut your hose, to get technique down, no matter what the tool.
    If you were trimming existing lines, you wouldn't even necessarily need to bleed the brakes.
