Results 1 to 3 of 3
    Trek 850 help - Rear Brake
    I was given a Trek 850 and have been going over it. I just replaced the bottom bracket. I was just trying to runa new rear brake cable and had a problem. On the model that I have there is a metal tube right at the seat post tube that the rear brake cable is to be run thru. Do I just run the bare cable thru it, or try to find some cover to fit in there? I tried to put the cover that came with the new cable into the tube but it would not fit. Help?
    Thank you.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    The housing should go into the noodle. The diameters have changed a couple times so you may have to go to the LBS with noodle in hand and get the right size.
    http://www.parktool.com/repair/
    Formotion Products
    http://www.formot
    Thanks. It took a couple of stops and then decieing to strip the cover off of shift cable to get it thru. Thanks again!
