Results 1 to 6 of 6
    Jul 2013
    Trek 4300 Disc Brake
    I'm looking to replace the front rotor and brake pads on my 2011 Trek 4300, but I'm not quite sure what to buy. Can anyone offer any advice?
    It has the stock promax dsk-907 installed however a simple google and amazon search yields no useful result.
    Jul 2013
    I'm thinking the rotors may be universal. But not sure on the pads.
    Rotors appear to be 160mm.
    Reputation: phoenixnr's Avatar
    Rotor braking surface needs to match the pad measurement. Other than that you are good to go. Some rotors recommend sintered vs organic pads. Check to see if there are any recommendations on pad type.
    Sent from my skz_tenderloin using Tapatalk HD
    B A N N E D
    Quote Originally Posted by vendethiel View Post
    The DSK-907 uses the same pads as the Avid BB7 and Avid Juicy.
    avid bb7 brake pads in Sporting Goods | eBay
    Hayes V6 MTB Disc Brake Rotor 160mm | eBay
    Jul 2013
    Quote Originally Posted by cobba View Post
    Feb 2013
    Also, depending on what brakes you ended up with, you either have centerlock rotors that match your centerlock compatible rims or 6-hole rotors for 6-hole rims. My 2011 happened to come with the centerlock setup
  1. Disc conversion trek 4300
    By bigfoot4300 in forum Beginner's Corner
    Last Post: 12-13-2012, 10:06 AM
  2. considering this.... 2012 trek 4300 disc
    By d0hface in forum Trek
    Last Post: 06-09-2012, 08:02 AM
  3. Trek 4300 vs 4300 Disc?
    By slumpey in forum Trek
    Last Post: 12-02-2011, 09:04 AM
  4. Trek 4300 Disc Owners
    By MikeeMellor in forum Trek
    Last Post: 03-16-2011, 04:14 AM
  5. $550 +/- Trek 4300 vs Disc vs specialized?
    By Fadelight in forum Bike and Frame discussion
    Last Post: 01-21-2011, 05:07 PM
