Results 1 to 5 of 5
    Tightening Hayes disk pad springs
    Has anyone had any success reducing Hayes brake noise by adjusting the pad springs, so they have a firmer grip on the post? If so, what did you do and how did you do it? Thanks. - Dave
    Sep 2004
    Quote Originally Posted by dnpeters
    I've never had to do this but you would probably, very gently, squeeze the spring together at the section that slips over the piston post.
    Another day in paradise!
    Mar 2005
    I some how doubt that will change anything, as when you brake you squeeze those things pretty firm. =)
    Have you tried softer pads? Hayes original are pretty soft.
    Reputation: bigdamo's Avatar
    Braided brake lines
    I all ways wondered if braided brake lines would fix this problem?It did on my moto X bike.
    Reputation: Eggman's Avatar
    tough one
    those things are a total pain in the butt, i know what you're dealing with. i've tried to twist and bend those things a couple times to get a tighter fit and it's a real challenge. i would love to see hayes come up with a better, more solid designed spring.
    i ended up grabbing one from an old set of avid mechs and that worked perfectly.
    sorry i wasn't more helpful, just sharing in your frustration!!
  1. Hayes MX2 pad equivalent ...
    By willtsmith_nwi in forum Brake Time
    Last Post: 03-25-2005, 12:09 PM
  2. broken hayes pad springs
    By tateb in forum Brake Time
    Last Post: 08-21-2004, 06:35 AM
  3. Hayes Brake Pad Replacements
    By J_B in forum Brake Time
    Last Post: 07-07-2004, 06:04 PM
  4. Mech Disk Brakes...Avid or Hayes???
    By BlurryTrees in forum Downhill - Freeride
    Last Post: 03-20-2004, 10:51 AM
  5. fork oil all over hayes pad
    By TMon in forum Brake Time
    Last Post: 02-23-2004, 08:10 PM
