Results 1 to 9 of 9
Thread: Ti Rotors
    Philze
    Reputation: philze's Avatar
    Ti Rotors
    I am looking to import these and see there is an issue with braking due to the distribution of heat and the brake pad compound. Would they work better if the rotors were thinner, say 1.8 mm. Is there a material to be added to the rotor, that would help the pad brake better? Say a mixture of alloy? Or is it better to find a pad that works with the existing material in the rotor.
    Aaron T. Collins
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by philze
    That's a poor material for a rotor. I had a set for a while and it wasn't a good experience. Others around here have tried with stock pads and non stock pads and there were no positive results as far as I remember. Do a search here as this has been discussed before.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with information and motivation.
    Do It Yourself
    Reputation: Homebrew's Avatar
    There is a company I know of that is working with a certain motorcycling brake mfg on Ti rotors for bicycles. Something about needed special treatment to work properly with regular pads. So it's a possibility but I really don't think those cheap Chinese Ti rotors will ever work out though.
    Long Live Long Rides
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Ti rotors for bikes are being used and at a high performance level. I've seen them.
    I expect that they will be commercially available in the not so distant future. Evidently the problems with heat can be, and have been, overcome. Weight savings for a set of rotors is almost a half pound over steel.
    A wheelist
    Quote Originally Posted by The Squeaky Wheel
    I just weighed a 160mm Ti rotor and a Marta wave (my lightest SS rotor). Ti = 69g. Marta = 107g. Diff = 38g or 1.34oz.
    Bodhisattva
    That weight savings was allegedly made on larger rotors. I'm not sure if the reference was 180 or 210mm.
    A wheelist
    If you're not careful I'll go & weigh a 140 for ya!
    Bodhisattva
    Quote Originally Posted by Mike T.
    140???
    Gee Mikey. You might as well not even have brakes. In fact, you prolly don't even need them up in flat old Ontario.
    Let's bring back the stick & metal bar. Someone should ressurrect that thread. It was classic.
    A wheelist
    140???
    Yeah a 140 is equal in power to a well-dragged Walmart sneaker. It's as flat as p!$$ on a plate up here in my part of Ont so most times we don't need no brakes.
    Actually, for me anyway, a rear 140 does a nice job.
    Metal bar? Hah that was jdcamb's attempt to copy my Oak Branch Instant-On Zeero Modulation emergency brake. Of course he failed and went off into the sunset, or prolly the weeds.
    **Now that I'm using CX-Ray bladed spokes I've had to go back to the drawing board with the Oak Branch due to longevity issues.
  1. Tech. content tubing, welds, Ti, Steel
    By vcyclist in forum Frame Building
    Last Post: 02-09-2005, 05:09 AM
  2. Ti 8" rotors for my 9er came in...119g each
    By ncj01 in forum 29er Bikes
    Last Post: 10-25-2004, 04:40 PM
  3. Dean Colonel Ti 29er.. Anyone...Anyone??
    By mdutcher in forum 29er Bikes
    Last Post: 10-04-2004, 12:31 PM
  4. ti rotors
    By thebronze in forum Weight Weenies
    Last Post: 09-26-2004, 10:15 PM
  5. Finally, my new Ti Racer-X is on it's way...
    By 1speed_Mike in forum Titus
    Last Post: 06-11-2004, 06:10 AM
