Theres no disc brake adaptor for my bike?
So this is a specialized hard rock 2013 bike and i was told those holes were for a kickstand, i thought new bikes like this one should at least have something that i can put a disk calliper adaptor on it
You have the entry level Hardrock. You would have had to move up a level to the Hardrock disc 26 in order to have disc brakes or the ability to have them.
 Originally Posted by shwinn8
+1 on the Brake Therapy
The only other option is fabrication and welding of a new bracket onto your frame, and that requires someone with the knowledge of the material and proper prep and heat treatment.
That thing works mint. I've installed it on a couple of bikes. ^^^^
$440 or so for a bike that doesn't have disc mounts
$175 for a Brake Therapy converter
More $ for a disc compatible wheelset
More $ for a disc compatible fork
More $ for disc brakes
If you wanted disc brakes you should of paid the $80 more and got the disc brake version of the Hardrock.
The cost of converting this bike to disc brakes isn't worth it in my opinion.
Leave the bike as it is or sell it and get a bike that has disc brakes.
* There is a cheaper converter then the Brake Therapy converter, the A2Z DM-UNI.
But I wouldn't even bother put one of those on that frame.
Check with your Specialized LBS...here is a quote strait from their webpage on the 2013 Hardrock frame.
Fully butted A1 Premium Aluminum frame with ORE down tube for a lighter, more compliant and durable bike, with disc mounts for upgrading
Specialized Bicycle Components
If this isn't the case then Specialized might need to explain themselves.
Same thing is written for the 2012 model, it actually has a brake mount on the frame.
2012 Specialized Hardrock
i concur... and one can easily find a mid 2000's complete bike on craigslist for about 500-700$ with mechanical or hydraulic brakes..
I never wanted to spend that much on a bike, disc brakes are not even a big deal to me, its just a luxury id like to have
Is your fork disc brake compatible?
Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
nope but the other bike i was planning to get for parts has hydro disk brakes
I had everything planned looks like i'll have front disk brakes
I'm sure buried in the back of the catalogue is copy saying spec and prices are subject to change without notice. Specialized is known for covering their legal hide after all.
that's more important anyways
Agreed, disc up front and just keep what you have in back.
Get yourself a $100 frame from price point? Might need a new bottom bracket, headset, and/or seattube.
- You may not post replies
- You may not edit your posts
Forum Rules
