Results 1 to 6 of 6
    are there still 4 bolt rotors???
    i've been toying around with an old hubset that used 4 bolt rotors. do any current manufacturers still make 4 bolt rotors that could be used with any modern brake system? the big concern of course being rotor diameter.
    thanks!
    Meh.
    Reputation: XSL_WiLL's Avatar
    I don't know what the pattern is. But Rohloff uses a 4-bolt pattern. Galfer also makes rotors to fit Rohloff hubs.
    Tribe Member
    Reputation: yetirich's Avatar
    There is this one on ebay....posted at 9.27 MST
    http://cgi.ebay.com/Magura-180mm-4-b...QQcmdZViewItem
    Good luck
    Proud Tribe member since 1992 - looking for better singletrack to be ridden year round
    Music & Bikes
    Reputation: fokof's Avatar
    I have some old DT/Hügi hubs that I love wich are 4 bolts, so after some reaserch found these:
    http://www.hopegb.com/voir_mm2disc_image_4.html
    Also Stan use to make their aluminium disks in a 6/4 bolts pattern , if you can find any
    Maybe there is other custom disk maker.......
    "There is a big difference between kneeling down and bending over" -FZ
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    I have a pair of barely used Magura Louise round 160mm rotors in the classifieds here for sale in 4-bolt configurations.
    My video techniques can be found in this thread.
    Music & Bikes
