    Is there an adapter to run 2000 XT on a Manitou fork?
    I have an old set of 2000 XT hydraulic brakes with 6" rotors and was wondering if there is an adapter to convert the caliper for using a Manitou post mount fork?
    Thanks a lot.
    On MTBR hiatus :(
    Yes, sort of...
    Shimano makes a 74mm PM -> 51mm IS adapter, but you'll need to purchase their 170mm rotor as well. The rotor and adapter are both listed in the QBP catalog.
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Yeah there is but you'll need a slightly bigger rotor. They make an adapter for 170mm rotors and one for 203mm. Check www.aebike.com
    Thanks, you are right...
    Quote Originally Posted by Hecubus
    I should have checked aebike, they list these adapters and rotors, it's a bit expensive for a 2000 set of brakes, I have to think about it, maybe better to buy a new set immediately....
  1. people, what do you know about this fork?
    By mikeb in forum General Discussion
    Last Post: 06-17-2004, 09:30 PM
  2. Which fork for Intense 5.5
    By Ronnie in forum Shocks and Suspension
    Last Post: 01-21-2004, 09:05 PM
  3. please help: '99 SID SL & 2000 XC compatibility?
    By Max in forum Shocks and Suspension
    Last Post: 01-20-2004, 10:42 AM
  4. Need disc brake adapter for manitou 74mm to 51mm
    By DIYguy in forum Shocks and Suspension
    Last Post: 01-18-2004, 08:05 PM
  5. 2000 Dare & Manitou SPV Air Compatible ????
    By Atomik Carbon in forum Ellsworth
    Last Post: 01-17-2004, 03:35 AM
