Results 1 to 3 of 3
    Reputation: gthcarolina's Avatar
    Mar 2005
    Tell me how to match Magura hs33 and disc
    I want to do hs33 rear and disc front. If I get a pair of hs33s can I put the front lever on a disc brake? Or is there another way to end up with levers that match or almost match?
    germs, needles, milk, death, snakes, mushrooms, heights, crowds, elevators
    Mar 2005
    Thanks for the info
    A wealth of info I could not find when I tried to search this. Apparently a few others have had the same idea. Do you run Magura brakes? I would like the two levers to look and act similar, but not necessarily be identical.
