Results 1 to 3 of 3
    Jan 2011
    tektro auriga not working
    Hi, my bike was recently stolen and I'm in the process of building a bike to replace it. Limited funds mean that I'm using old kit I have saved.
    I found and old set of tektro auriga comp brakes and fitted them to myframe but when I came to put the wheel on the pads were very tight, it took a bit of effort to open them up enough that the disc would slip between the pads.
    Once I had sorted that the brake pads now still touch the disc all the time and when I squeeze the brake lever the pull is really weak.
    Do these brakes just need bleeding or are they knackered after 3 years sat in a damp garage?
    Cheers
    Reputation: Aresab's Avatar
    You could try a few things:
    1. They may need a mineral oil fluid change, not real hard to do with their kit and the included syringe. My Shimano's needed it after a few years.
    2. You could pump the lever a bit with pads out and caliper in hand, just a bit so the sides of the piston show, but not too much to pop it out of the seal. Then dip a clean q-tip or similar in the Tektro mineral oil and go around the piston to lube it. When done push the piston back then cycle the piston in and out a few times. This is an old Shimano trick.
    IF there is no internal damage, you should be okay after that.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Quote Originally Posted by RSabarese View Post
    This is a good place to start for sure.
  1. Best pads for Tektro Auriga Pro?
    By ddgdl in forum Brake Time
    Last Post: 03-19-2013, 08:31 PM
  2. need help with tektro auriga comp
    By beowulf62 in forum Brake Time
    Last Post: 03-02-2013, 04:43 PM
  3. Tektro Auriga Comp Disc Brake Pads
    By OFFcourse in forum Brake Time
    Last Post: 09-15-2012, 12:00 PM
  4. tektro auriga comp brakes...
    By Brandon, in forum General Discussion
    Last Post: 04-16-2012, 08:05 AM
  5. Tektro auriga comp squeaking like a pig
    By skewe in forum Brake Time
    Last Post: 12-09-2011, 10:03 AM
