Results 1 to 6 of 6
    Reputation: OFFcourse's Avatar
    Tektro Auriga Comp Disc Brake Pads
    Need to replace the pads on my dirty stocks.
    CRC have the standard ones here... Tektro Tektro Aquila/Auriga/Auriga Comp Pads | Buy Online | ChainReactionCycles.com
    Want to try something different, suggestions for something a bit quieter?
    Reputation: Aresab's Avatar
    The good thing about the Auriga series is they use the same pad as the Shimano Deore M525 (not M535, M585, M760/770) so they are readily avaiable. I use ebay's Bikefridge pads with good success. The stock pads are not really good in my experience.
    no trees are safe
    Reputation: Millfox's Avatar
    Jun 2012
    You can fit in pads from Shimano m515/m525 as well. They're same design.
    no trees are safe
    Jun 2012
    Nukeproof have very good references. I'm planning to buy 2 pairs my self.
    Nukeproof Shimano Deore M515/M525/Tektro Disc Pads | Buy Online | ChainReactionCycles.com
    Thanks, I will pick up a pair of Nukeproof Shimano Deore M515/M525/Tektro Disc Pads with my next order.
    Need a 9-speed chain also, I'm coastal so anything corrosive resistant is good, light cheap etc.suggestions? Through CRC is easy for me too
    Feb 2012
    i used EBC greenstuff compound and i am very impressed i run a sram chain with great success
