Results 1 to 2 of 2
    Switching 6" Promax disc brakes for 8" Avid Mechs
    Should I expect any complications or should the new brakes fit the standard mounts?
    It should be a comparatively easy swap. Take your time, read the instructions 2 or three times before you even touch a tool, and make sure you have a good idea of what's going on.
    While you're at it, pick up some new cable housing and cable, since the old housing may or may not be long enough. This would be a good time to invest in some teflon coated cables, and a good cable cutter. Make sure your cuts are good... search the forums for tips on cutting housing.
    But yeah... mounts shoudl be the same.
  1. Tektro and Promax disc brakes
    By TR in forum Singlespeed
    Last Post: 08-09-2004, 08:05 AM
  2. Are avid disc mech's front and rear specific?
    By jxq25 in forum Brake Time
    Last Post: 07-15-2004, 04:25 PM
  3. Avid Mechs Report (Long)
    By Warp in forum Brake Time
    Last Post: 07-13-2004, 09:00 AM
  4. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  5. Avid Mechanical Disc Brakes
    By FUEL in forum Brake Time
    Last Post: 03-11-2004, 11:12 PM
