Results 1 to 3 of 3
    Mar 2006
    Switch to Post Mount and Caliper Alignment
    I just switched from an IS fork to a post mount and can't get my Juicys to stop rubbing on the inside pad. I've pushed the pistons all the way in and realigned CPS bolts ad nauseum. It seems that if I added like a millimeter washers in between the rotor and hub, that it might stop rubbing. But I wanted a second opinion first.
    Here are some pics:
    Also the fork is a Manitou with a reverse arch that has me guessing at proper cable routing.
    Here's how I have it now, I'm currently unsatisfied with the tie to the crown as it rubs when the fork compresses:
    Ideas?
    You can use thin washers to space the rotor.
    And as for the brake hose, try this:
    Stupid question..
    Mar 2006
    Cool idea with the tubing, thanks!
