Results 1 to 3 of 3
    29er for the Soul
    Reputation: teachndad's Avatar
    swapping wheels w/BB7 rotors with 201? Avid Elixer 1 rotors Compatible?
    Hi,
    I am about to pull the trigger on a 2013 Santa Cruz Superlight 29. The Superlight comes with Avid Elixer 1 brakes. (Not sure if these come with 2012 Elixers or 2013). My old ride, a 2009 model 29er has BB7 brakes, but the wheels are upgraded. So, I want to swap out the new wheels on the Superlight with the wheels from my old rig.
    Are the rotors compatible with the other manufacturer? That's the key question.
    Can I slide the wheel in or will i have to swap the rotors to the other wheels?
    A possible problem: I don't know if what rotor mounting system is used with the Superlight. My old rig uses a centerlock on the rear and the front uses a 6 hole.
    Cheers.
    So Cal Rod
    WillWorkForTrail
    Jun 2012
    If the rotors are the same size, everything should be cool. Besides, BB7's are Avid brakes, so there's no brand issue there. If the rotors aren't the same size, you'll either have to change mounting adaptors on the calipers or swap rotors.
    Reputation: Fuglio's Avatar
    Put the new ones on.. not cause you have to... Do it cause they are new...
  1. XTR brake/Avid rotors compatible?
    By RTM in forum Brake Time
    Last Post: 10-16-2012, 08:21 AM
  2. Avid HS1 rotors with BB7?
    By dslfoolish in forum Brake Time
    Last Post: 06-28-2012, 10:32 AM
  3. Replies: 3
    Last Post: 08-17-2011, 09:11 AM
  4. Swapping 185 stock rotors with 180mm ashima
    By eddie80 in forum Weight Weenies
    Last Post: 07-25-2011, 08:10 PM
  5. Formula R1 rotors compatible with XT brakes?
    By Scottyman in forum Brake Time
    Last Post: 04-09-2011, 09:52 AM
