    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Swapping calipers
    So I'm swapping out the X2 for an M4 and will be using the same levers and same lines. My plan was basically to just swap them out at the banjo bolt and bleed the system as the caliper needs to be filled with fluid. Am I missing anything?
    No. Your working with Hope products, it really is as easy as that. Enjoy the extra power and a little more modulation.
    Epic rider
    Reputation: rapsac's Avatar
    Sep 2004
    Re: Swapping calipers
    No, but you might want to use new copper washers for the banjo.
    12 Anthem X29
    13 XTC 29
    07 Epic Marathon carbon
    04 Stumpjumper FSR Anniversary
    03 Stumpjumper FSR Pro
    00 Rockhopper Pro
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by rapsac View Post
    Yeah, the new caliper came with a complete banjo assembly, including the copper washers. I had planned to swap those out as well, but reuse the old banjo.
    Thanks all. Looking forward to NOT overheating my rear brake!
  1. Swapping Avid BB5 for BB7 - calipers only?
    By jbartlett79 in forum Brake Time
    Last Post: 11-27-2012, 09:24 AM
  2. BB7 Calipers?
    By cstem in forum Arizona
    Last Post: 10-03-2012, 05:06 PM
  3. New calipers or new brakes?
    By old crank in forum Brake Time
    Last Post: 05-22-2012, 11:41 PM
  4. V2 calipers with X2 pads?
    By anlin in forum Brake Time
    Last Post: 02-21-2012, 11:55 AM
  5. Swapping calipers
    By opiants in forum Brake Time
    Last Post: 01-07-2012, 02:11 AM
