Results 1 to 5 of 5
    Swapping calipers
    So I changed my brakes and now have a spare j3.
    I'm planning on changing the calipers on my wife's ride. She has tektro mech disc brakes atm. Can I just pull the calipers out and change it with j3s or do I need another set of rotors?
    T.W.O.
    Reputation: mimi1885's Avatar
    Your wife tektro is a mech, and J3 is Hydro, there's no way that would work
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    If the op changes everything from the M/C to the caliper including the caliper adapter it would work no?
    T.W.O.
    My bad yes op can do that. It just pretty much change the whole thing out. Op to answer question it's best to use the same J3 rotors so you don't have to bed them in again as long as they are still in good shape.
    Thanks AZ,
    Thanks. I do have the rotors and they are in good shape but they are a bit overkill for her as they're 185...
  1. Swapping my ARC for an ARC Ti
    By casnell in forum Yeti
    Last Post: 05-30-2010, 12:07 AM
  2. Swapping SPV for TPC
    By D-Avid in forum Shocks and Suspension
    Last Post: 12-25-2006, 05:03 PM
  3. Swapping wheels
    By kdiddy in forum Brake Time
    Last Post: 04-19-2006, 09:50 PM
  4. EBB and cog swapping
    By Karo in forum Singlespeed
    Last Post: 03-31-2006, 02:56 PM
  5. Replies: 2
    Last Post: 09-26-2005, 03:51 PM
