Results 1 to 8 of 8
    Reputation: kersh13's Avatar
    New question here. Swapping brake hoses - DOT fluid to mineral oil okay?
    I am looking to upgrade my old Juicy 5s to some new Shimano XT M785s. I have a nice set of Jagwire hose that I've been using on my Juicy 5s for the last 2 years. Here's my question:
    Will the hoses be okay to swap from the DOT fluid to the mineral oil for the Shimanos? Obviously, I would have to clean the hoses well and buy a new fitting kit from Jagwire. I guess my main concern is getting the hoses clean enough from the DOT fluid to make the swap.
    Anyone have any experience with this sort of thing?
    - Just livin' the dream -
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    no experience with the diff fluid types. i have changed hoses due to color choice with great success on my J 5's and hayes strokers. whats the reason for changing fluids??
    "ORANGE IS THE NEW BLACK"
    thread crapper
    I can't see any reason you couldn't flush out the old fluid with some new stuff. Might not be the most cost effective situation, but I can't see why it wouldn't work.
    NV - Shimano uses mineral oil, not DOT fluids like Hayes and Avid.
    gone walk about
    Mar 2012
    Quote Originally Posted by scottap2003 View Post
    ahhh shows how little i know of them.
    I have the matching red hoses from Jagwire for my derailleur cables and my brake hoses. Plus, the cables are already cut to the correct length. I think the fitting kit from Jagwire is just over $15 so it shouldn't be too much extra.
    You're saying to flush out the lines with mineral oil? Does water affect mineral oil like it does DOT fluid? I thought about running water through them, then spraying them out with the air compressor, then letting them dry for a day or two. I just don't know if that would hurt anything though.
    Sep 2012
    I would just pull the cable off, spray brake cleaner down the cables then blow them out with air. The brake cleaner will evaporate without any residue. Then put them on the new caliper/lever setup and fill and bleed the system.
    gone walk about
    Mar 2012
    Quote Originally Posted by TJay74 View Post
    brake cleaner will do the deed for sure. i also thought about alcohol as a 1st step.
    thread crapper
    Yeah, Shimano is always saying to use isopropyl alcohol to clean everything, so I guess that'd be a cheap way to clean em out. Any water in any hydro system is bad. It might not react with the fluid like it does with DOT, but it still lowers the boiling point of the fluid. Your idea of blowing them out and all sounds like it could work. I'd still run some mineral oil through them a bit before putting it all together though.
