Results 1 to 9 of 9
    Suggestions on upgrading Juicy3 on GF x-cal
    I am looking for system with quick finger tip control, weight not too much of an issue. I am 245. Brake fade and wet performance is number one.
    Have 185 front and 160 on rear, should I upgrade the rotors as well? Do I need to change the rotors also?
    I don't have a max price range but let's say 500. I could do more no prob if there is good reason.
    I ride single track, some xc
    Please help me find great upgrade. I like all of the bike with SRAM 7 on the rear and 9 on the front, even the SRAM 7 triggers are great
    Thanks in advance for any help
    Reputation: Shalom's Avatar
    Nov 2008
    Good options include XTR trail, Elixirs, Hope Tech X2 or M4.
    I am currently running Hopes and love them. Power, modulation, adjustability....not sure I will use anything else now.
    I will look into the Hopes a little more, which set do u run? I read some about them earlier and sounded impressive. As far as xtr, is there a reason to drop the jack over the xt except for the weight?
    Nov 2008
    Am running Tech X2's and M4's on different bikes. M4's are burlier. Both are fantastic. As for which to get - depends on what you see yourself doing.
    Shimano - from what I gather and have read, there is not much difference between the XT and XTR other than weight and finish.
    Single trac, so quick response and low fade are number 1,,, so xt, then am familiar with m4s a tad. Will look into tech 2's also
    But riding is 90% st.
    Which set in your opinion is tougher?
    Thanks again
    Nov 2008
    The M4s are stupidly powerful.
    X2 is also bloody good.
    I have not used the XTs, but they should be pretty much the same as the XTRs, which have plenty of power too.
    FWIW, I just love my Hopes for their sheer 'usability'. But it is very much personal preference and budget.
    Wink
    Shimano - from what I gather and have read, there is not much difference between the XT and XTR other than weight and finish.[/QUOTE]
    Except for the price
    Nov 2008
    Quote Originally Posted by Iceman30 View Post
    Except for the price[/QUOTE]
    Well, there is that too, of course
    MTB Noob
    Will XT/XTR's upgrade ok from my Juicy 3's? (Same mounts, etc)
    I've been turned off Avid massively from MANY reveiws saying they suck in the long run??
  1. Upgrading!!! But i need suggestions
    By Agent-Boltron in forum Shocks and Suspension
    Last Post: 07-09-2009, 03:57 PM
  2. AVID Juicy3 issue
    By Gatzek in forum Brake Time
    Last Post: 06-02-2009, 08:26 AM
  3. carbon levers for the juicy3
    By rize5boyuk in forum Brake Time
    Last Post: 03-02-2009, 02:13 PM
  4. XTR V vs SD7 vs BB7 vs Juicy3
    By shadesy in forum Brake Time
    Last Post: 12-15-2008, 10:00 AM
  5. juicy3 vs juicy5
    By logigamer in forum Brake Time
    Last Post: 05-04-2007, 10:22 PM
