Thread: Stroker bleed
    mtb
    Reputation: aintnothang's Avatar
    Stroker bleed
    I was looking at this cheap bleed kit on ebay. I was wondering what fitting it is they use because I have most of the other components.
    http://imgs.inkfrog.com/pix/cs.for.q...-bleed-kit.jpg
    LightJunction.com
    Reputation: lightjunction's Avatar
    My notion is that it's proprietary. However, you can probably order one through your LBS from Hayes-Stroker. That would certainly be cheaper than a new bleed kit.
    I've made some of my own bleed kits before. I usually just find a piece of tubing that will fit directly to the bleed screw on the brake caliper...that way you don't have to buy a fitting.
    We sell quality bike headlights and flashlights.
    www.LightJunction.com
    mtb
    just bleed it through the back and let the excess pour out of the handle?
    LightJunction.com
    That's the method I've used. I wrap a shop rag around the brake lever to absorb the excess fluid that spills out of the master cylinder.
