Results 1 to 14 of 14
    Mar 2006
    STRIPPED TORX T25 head - AVID cleansweep ROTOR SCREW
    I stripped the torx t25 screw head and now i cannot get the rotor off.
    what's the best way to remove the screw?
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    You can use a hacksaw or a dremel and cut a groove into it and remove it with a flat blade screwdriver
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Mar 2012
    If its raised above the rotor. It would be easiest to grind a slot in the head with a dremel tool and a fiberglass reinforced cutting bit. This will let you take it out with a flat head screw driver. Just be careful not to cut your rotor!
    How did you strip a torx bit anyway?
    Mar 2006
    i was in a rush and stripped the head.
    Ride Responsibly
    Reputation: LWright's Avatar
    Slow down. The slot and screwdriver is good advise, I want to add to that with this tip. Use a hammer to tap the driver into the screw as you turn it, this helps reduce stripping. You can also try this with a larger 27 torx.
    If that fails you can drill off the head and use vise grips on the bolt. Usually no torque on the bolt once the rotor is removed.
    Mar 2013
    Small vice grip might do it. Removing off others might let you rotate the rotor and undo the bolt although that might damage the hub if you aren't careful. It may not take much to get it going.
    Plays with tools
    Reputation: customfab's Avatar
    I've always been successful drilling the head off, removing the rotor and grabbing the stub of a bolt with some vise grips.
    Personally I wouldn't tap the screwdriver into the bolt. If you hit it too hard your just going to make life harder on yourself.
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    Quote Originally Posted by customfab View Post
    another good method.
    this method is liken to a hand held impact driver and works well.
    "ORANGE IS THE NEW BLACK"
    Plays with tools
    Quote Originally Posted by nvphatty View Post
    It's not though. An impact driver applies torque, a hammer on the screwdriver puts force down the axis of the bolt, increasing the plastic deformation that keeps fasteners tight.
    Reputation: Jakerz's Avatar
    Jun 2013
    It also shocks the joint which in most cases will break the threadlock and allow you to looses it, I've used this before and it does work. You could also pick up a handheld impact driver for under $20 at Harbor Freight or auto parts store.
    One Gear
    Reputation: .40AET's Avatar
    If all of the other bolts are already out, put them back in and torque them down. This will remove some of the tension on the stripped bolt.
    Good luck
    gone walk about
    Mar 2012
    yes indeed it is IF applied with the necessary twisting force just as an impact does. It's quite effective in many cases but not all.
    change is good
    Sep 2004
    Vice grips. Don't crush the bolt head.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Re: STRIPPED TORX T25 head - AVID cleansweep ROTOR SCREW
    You could try these.
    http://m.sears.com/productdetails.do...r=00952154000P
    They're made for extracting phillips head but i don't see why they wouldn't work for torqx, the idea is the same - sharp reverse threaded threads which dig themselves into the medal. If it doesn't work, trust me you will use those someday and they will save you a lot of hassle.
    Sent from your phone, which i hacked into
  1. Replies: 1
    Last Post: 02-25-2013, 11:06 AM
  2. stripped screw on EBB - any Ideas?
    By OSnap in forum 29er Bikes
    Last Post: 04-17-2012, 09:29 AM
  3. Replies: 20
    Last Post: 01-07-2012, 05:25 PM
  4. T25 Torx for Rotor keep stripping...
    By bikeman1 in forum Beginner's Corner
    Last Post: 10-11-2011, 03:02 PM
  5. CleanSweep X Centerlock Rotor Weight?
    By brentos in forum Weight Weenies
    Last Post: 02-01-2011, 11:28 AM
