Results 1 to 14 of 14
    Stripped Rotor Bolt...How do I get it out?
    I saw some rust around my rotor bolts, so I decided to take them off, clean the disc, then replace the bolts. Of course, one bolt won't move, and I've stripped it smooth. I tried drilling it out, but I've only got a hand drill so I can't seem to drill it out very fast. What do I do now? Cut a flat cross-wise slice through it, then try to turn it with a blade?
    This happened once before, and I took the wheel in to a bike mechanic, and the bugger just turned the thing out with an allan key, no problem. I've tried and tried and tried, but no dice.
    Reputation: spookyload's Avatar
    Hit it with penetrateing fluid or WD-40 for a bit then give it a go again.
    Trying a little
    Reputation: dusthuffer's Avatar
    Nov 2006
    lightly tap in a torx head of just the right size and back it out
    I never apologize. I'm sorry, but that's just the way I am.
    Meh.
    Reputation: XSL_WiLL's Avatar
    You can cut off the head and grab the remaining post with a pair of vice grips. You can cut flats on the side so you can grab at it. You can cut a slot in the head and use a screwdriver. You can tap in a slightly larger torx/allen. You can use an easy-out.
    I think I'm going to drill the head, right down to the body of the screw. It should just pull off if I do that. If that doesn't work, I'll try the other cuts. What sort of cutter would work? is there a small cutter with a round blade that I could use for that?
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    Quote Originally Posted by Jayzonk
    That should effectively 'cut' off the head just fine - just use a bit slightly larger than the threads
    Honestly... ahh I give up
    trail addict
    Reputation: Uncle Six Pack's Avatar
    +1 on that one... did it once myself. If you have a flathead attachment for a little mini-ratchet drive, it will give you all the leverage you need... also maybe a soldering iron to heat up the threadlocker could help.
    You better just go ahead and drop that seatpost down to the reflector... the trail gets pretty rough down there.
    Dremel would be perfect
    It's time to be a WW. Run 3 bolts LOL
    Dec 2008
    Dusthuffer wins this one! Tapped in the torx head with a mallett then I just attached the torx wrench and torqued it out - no problem! Came out in 5 seconds! Thanks Dusthuffer!!
    Reputation: scoutcat's Avatar
    the safe method would be to use a bolt extractor kit.
    Trying a little
    Nov 2006
    I cribbed that move from trailbait, gotta give credit where credit is due.
    The Beast Breathes
    Reputation: mountain_bomber156's Avatar
    There's a, uh, bolt remover for drills somewhere...
    http://www.4grabit.com/Default.asp?bhcp=1
    Good luck with that, mister 300-Mile Turn Radius.
