Results 1 to 5 of 5
    Stripped disc hub screw hole
    So I guess the bicep curls have been working...I stripped one of the screw holes on my rear Mavic Crossmax XL. I now have only 5 holes. Has anybody had this happen and what did you do? Can I ride it like that? I assume tapping it won't work because that would just make the hole bigger. I am thinking of just going to the hardware store and getting a nut to put behind the hole. First post...thanks in advance.
    Reputation: Hardtails Are Better's Avatar
    May 2005
    5 bolts will hold your rotor on fine. If you want, get a longer bolt and an M5 nut and do that up.
    Reputation: mtnbiker1973's Avatar
    Heli coil.
    Reputation: vk45de's Avatar
    It's not just strength that counts, you need dexterity as well. You're lucky it's the rear where you can get away with it. It's a crossmax, so the pawls will go fast taking the axle with it too if you don't maintain it well. So don't worry.
    Meh.
    Reputation: XSL_WiLL's Avatar
    As said, 5 bolts are fine. You can use a nut on the other side if you want. Or you can helicoil it.
