    Banned
    anyone familiar with Avid Elixir brakes?
    My forearms are getting killed by my Elixir 3 levers. I checked into it a little but could only find this .PDF released by Straitline Components: http://www.straitlinecomponents.com/...patability.pdf
    Basically, it speaks of the Elixir 5, the Elixir R, and the Elixir CR. It doesn't list whether or not Elixir 3 is compatible.
    I was hoping someone might be able to tell me if Straitline lever blades are compatible with Elixir 3 brakes. The reach adjustment doesn't save my arms and it's getting old having my arms so worn out at the end of a ride.
    Banned
    bump
    Reputation: thekrow4jc's Avatar
    It can't be done. How the lever body holds the lever in is completely different from the rest of the elixir line up. On the elixir 3 the lever is screwed into the body and the spacer slot is open ended so once the screw is taken out it just pops out, where as the rest of the elixir levers are held in to a closed ended spacer slot.
    Found this out the hard way, just got my straitline levers, and figured out it won't work on elixir 3 levers. Time for brake upgrade!
    Banned
    yeah I didn't get the Straitline levers, I just ended up with XTR
  1. Elixir 3 - bad lever?
    By Earthpig in forum Brake Time
    Last Post: 07-27-2011, 08:39 AM
  2. Straitline lever compatibility
    By spreadthedecay in forum Brake Time
    Last Post: 02-17-2011, 06:06 PM
  3. Elixir CR Lever ID
    By illini in forum Brake Time
    Last Post: 11-15-2010, 05:45 AM
  4. Replies: 7
    Last Post: 10-24-2010, 01:29 PM
  5. Replies: 1
    Last Post: 08-19-2009, 08:24 PM
