Results 1 to 19 of 19
    Storing bike w/Martas upside down
    I'm going to invest in new disc wheels and brakes this fall. Trying to decide which brakes. Magura Martas seem to be the brake of choice these days, and the light weight appeals since I am pretty strictly an XC rider.
    The manual for my Fox Float RL Fork says to store the bike upside down to let oil run into the foam rings and keep them saturated. But I seem to recall reading that storing a bike with Martas upside down will cause them to need bleeding more often.
    Do any of you Fox/Marta owners have any thoughts on this?
    Maybe I should just get some Avid Juicys. Low maintenance is a top priority for me, but I'm pretty sure I want to go hydraulic.
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Hydros are hydros and the principals of not storing any of them upside down are the same. The majority of problems with any hydro brake arises from improperly bleeding & installation.
    Bottom line: if the brakes are bled properly, there is no problem storing them upside down. It is only when they are improperly bled, and air is hiding in the system, that turning them can create problems. It's not the act of turning them upside down, but rather the simple disloding of hidden air bubbles.
    As for the Fox, I've had 2 Fox forxs over the past 3 years and haven't had any problems with the foam rings & I store mine in a stand upright. Every few months I'll lift up the seals and add a small amount of fork oil to the foam rings but they've always been moist except after long winter storage.
    A wheelist
    Reputation: Mike T.'s Avatar
    Quote Originally Posted by riverrat
    Magura Martas seem to be the brake of choice these days.....I seem to recall reading that storing a bike with Martas upside down will cause them to need bleeding more often.
    Let's take a look at this and insert some reasoning. Air getting into the brake system when the bike is inverted is always user error. If you read 1Speed Mike's fine bleeding instructions that were posted on this forum today it's impossible for this inversion air entry to happen. Just about the same instructions (provide to me by MaguraUSA) are on my Magura Cult site.
    If air does get into your lines due to inversion it can only get there from one source - the reservoir. It couldn't have been in the lines before this or you would have had a spongy brake.
    If you follow all of Mike's instructions to the letter (this why no-one should let anyone else bleed their brakes!) then you could ride your bike upside down while pumping the brakes and no air could enter. How could it? There's none in your system.
    Mike's explanation of expelling the air from the reservoir is perfect. How could it not be? He's an engineer and hydraulic bicycle brake expert.
    As your pads wear and fluid is needed from the reservoir to extend the pistons, the bellows expands and air enters BEHIND the bellows through the cap vent hole. This allows internal reservoir pressure to equalize. The bellows is a flexible membrane that separates the fluid from the atmosphere.
    If you change pads at the factory recommended thickness then the reservoir (and bellows) will have enough capacity to accommodate the wear.
    Don't fault Maguras because of the inexperience of others.
    Mike T. (mcm # 717 & FOG)
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with information and motivation.
    Quote Originally Posted by Mike T.
    Read my post carefully. I wasn't "faulting Maguras because of the inexperience of others".
    I wrote that I had read somewhere that storing Magura brakes upside down caused them to need bleeding more often. This is different from making such an assertion myself.
    I am not an expert on the conditions under which air gets into hydraulic disc brake lines, causing them to need bleeding, because I have never owned disc brakes.
    The point of my post was pretty clearly to inquire whether what I had read about upside down storage of Maguras was an issue or not, given that I have a Fox and they recommend storing bikes with their forks upside down.
    I do appreciate knowledgeable people debunking this apparent myth.
    Mike T, 1Speed, and Squeeky,
    Thanks for expelling the myth and settling this once and for all. I just got the Martas (non-SL, great looking in BLACK btw!) and am loving it.
    (aka SS_MB-7)
    Reputation: 1speed_Mike's Avatar
    Quote Originally Posted by DALI
    No worries! Enjoy your new Martas and welcome to the Cult!
    Ride Hard,
    Mike B. (MCM# 7.77)
    http://www.one-speed.com
    This is my first cult!
    BTW, I just received my latest MBAction magazine last night and it was ironic that they recommended as a rule of thumb not to hang one's bike updside down with disc brakes. I do enjoy the magazine (advertising, perceived bias and all), but this was the first time I strongly disagreed with them. Especially after reading the well informed posts here.
    Now I'm off to riding. Final note -- I never thought I would use any brake levers other than Avids (I had the Ultimates previously mated to Avid Mechanicals) but the Martas are just as swank!
    Bodhisattva
    Funny you should say that. Over the past few years I had briefly tried Avid Mechs on various bikes. My impressions were strong but grabby & I didn't particularly care for them.
    Recently I've been riding my friend's bike a lot which has a 8" front & 7" rear Avid Mech and really liking them. Not more than my Louise FR, but more than I have in the past. Then again, it's a 35# freeride bike so the extra weight & a bit of grabbiness doesn't hurt.
    Marta newbie
    Hey guys I was just reading your post and I finally jumped on the hydro bandwagon and ordererd a set of martas not the sl. I have been riding avid mech. discs for about 2 years. I know there are some major performance increases from cable to hydro but I was curious about the bike hanging thing. I currently hang mine not upside down but from the front wheel. Cuts down on the clutter in my garage. Me being new to hydros I do not want to incur any headaches to my first experience. What I'm getting at I guess is can you truely store the bike hanging upside down or by the front wheel?
    Thanks for any info.
    Bodhisattva
    Tom,
    I don't mean to sound rude, but have you read this thread?
    I have
    I guess if they are properly maintained is the correct answer. Sorry trying to squeeze in net time at work. Was in a hurry. Do you have experience wiyh hanging bikes with hydros or is this speculation?
    Bodhisattva
    Quote Originally Posted by tom schoonveld
    Correct.
    Let me capsulize this for you: the system is closed. Air cannot enter. Hidden air can be dislodged by turning the bike upside down, turning it sideways, upright, looking at it funny, thinking bad thoughts, etc....
    Any "need to bleed" caused by movement of the bike is the sole result of incorrect bleeding in the first place.
    Yes, I have first hand experience.
    A wheelist
    I know there are some major performance increases from cable to hydro.
    Can you share these major performance increases with us?
    Reputation: DH_WP's Avatar
    If you can store the bike upside down ... can you
    Run the levers on the opposite side ? and upside down ?
    The reason I ask is I have a set that I have not mounted yet , but they are prebled and are left/front and Right/back . by running them upside down they are left/back right/front.
    I am bit worried to try and switch the lines.
    thanks
    A wheelist
    Quote Originally Posted by DH_WP
    thanks
    Running levers upside down is not the thing to do but most hydraulic brakes can have their lines switched without bleeding. I know this is a fact with Magura and Formula brakes. You didn't tell us what you have so I can't be more specific.
    The brakes would be..
    The Marta SL's
    A wheelist
    The Marta SL's
    Uhh then no sweat. The info will be on Magura's site under shop manual downloads, in your yellow shop manual or on my Magura Cult site. It's under the "Shortening Hose" section in the manuals. On my site it's under Self-Adjust brakes/Brake Lines/Going Moto. Read mine first
    Mike T. (mcm # 717)
    Thanks for the info
    The brakes are not on the bike yet and are sitting in the box. Suppose it is easyer doing the swap on the bike. will try the weekend.
    thanks for the info , love the site .. you must really love your brakes , cant wait to try them out.
    Mike T. (mcm # 717)
    A wheelist
    Thanks for the praise on the site. Do the switcheroo with the brakes on the bike as it holds things firmer plus you may need to shorten the lines anyway. Of course I have that info too. Don't forget the most importand thing - " Don't let that line wave around, wag, dangle or snap away while you're doing the swap or you WILL lose fluid. Move slowly and use a helper."
    I personally wouldn't attempt this without having a bleed kit on hand. Murphy's Law is relentless.
  1. Mountain bike jargon/ lingo
    By bstguitarist in forum Beginner's Corner
    Last Post: 05-26-2005, 12:02 PM
  2. Forks, Frames and Five Hundred Dollars.
    By AdamOn6thStreet in forum Clydesdales/Tall Riders
    Last Post: 02-25-2005, 10:10 PM
  3. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  4. Lance's Austin "29er" revealed
    By ncj01 in forum 29er Bikes
    Last Post: 08-28-2004, 08:14 PM
  5. opinions
    By ScotchtapeLoser in forum General Discussion
    Last Post: 04-16-2004, 12:16 AM
