Results 1 to 7 of 7
    Jul 2013
    Stiff Hydraulic Disk Brake
    So as you probably know, pulling a hydraulic disk brakes lever is extremely easy and it will give you a fast response. However my front lever is extremely stiff. Like as if it was already pulled half way. I tried taking out some fluid but it didn't work.
    NOTE: The wheel still turns flawlessly, no rubbing...
    Reputation: Danielrg_usa's Avatar
    Do they work fine otherwise?
    Jul 2013
    Yes, but I can't slowly pull the lever and come to a slow stop, instead when I pull the brake lever I come to an abrupt stop.
    Reputation: Tillers_Rule's Avatar
    Sep 2004
    When is the last time you bled the brakes? Not just letting out fluid, but cycling new fluid into the system.
    Jul 2013
    Never, so you mean replacing the fluid?
    What brakes?
    It could potentially be that the brake pads are too close to the rotor for that particular brake (even if it's not rubbing). Sometimes that can happen if the lever is accidentally squeezed when the rotor is out of the caliper (i.e. wheel removed). I suggest taking the pads out and pushing the pistons back all the way with a plastic tyre lever or similar. Put the pads in and the wheel back and continually pump the lever to put the pads in the "correct" place.
    This is easier to do than bleeding, so it's worth a shot to try first.
    Jul 2013
    ok Ill try it this weekend thanks!
  1. Replies: 104
    Last Post: 12-29-2016, 08:05 AM
  2. Adjusting Shimano M445 hydraulic disk brake lever reach
    By User2 in forum General Discussion
    Last Post: 06-07-2013, 05:38 AM
  3. Hydraulic Disk Brakes
    By CannondaleF9 in forum 29er Components
    Last Post: 03-13-2013, 05:08 PM
  4. stiff/too long Avid hydraulic cables
    By louisd in forum Brake Time
    Last Post: 01-05-2013, 04:33 PM
  5. Hydraulic disk brake problem
    By Ali_ in forum General Discussion
    Last Post: 12-18-2012, 06:18 AM
