Results 1 to 11 of 11
    sram code RSC a1 vs b1 - what's the difference?
    The prices are a bit different, but the specs look the same. Anyone know the difference between the two?
    B A N N E D
    Probably a slight difference in the caliper or the lever, the Spare Parts Catalog doesn't show anything for the B1 Code RSC, from what I can see, it only shows the A1.
    With other brake models there is slight differences with either the caliper, the lever or both with the A1 and B1.
    Jan 2017
    Quote Originally Posted by wingsno19 View Post
    Pretty sure the only difference is the incorporation of the bleeding edge port on the caliper and upgraded plunger in the lever.
    how can you tell which version is which? i just bought code rsc brakes a few months ago
    2017 yeti sb6c turq x01 eagle
    Jan 2017
    A1s have a bleed nipple, B1s have the bleeding edge port on the caliper.
    pics here: SRAM Guide R vs Guide R (B1) version
    Quote Originally Posted by Supah Dave View Post
    thats for the guides. are the codes the same way? i didn't know they even made the new codes without the bleeding edge port, since they are pretty new. first time im hearing about an A1 and B1 version of the codes.
    Big M, Little organ.
    Quote Originally Posted by useport80 View Post
    Correct. All SRAM codes from 2017 on have bleeding edge. I thought B1=R and A1=RSC caliper. The R and RSC calipers differ slightly. Are you sure itís a B1 RSC and not R???
    Reputation: mpress's Avatar
    The B1 is the second generation of the Guide brakes (R, RS, RSC). They feature the S4 caliper with the "Bleeding Edge" bleed port, improved heat resistance, and improvements to the brake lever.
    https://www.pinkbike.com/news/sram-u...4-caliper.html
    Quote Originally Posted by mpress View Post
    Thread is about codes, not guides. That information doesn't apply.
    Quote Originally Posted by Organ View Post
    Must of glazed over that part...
    Code is a different caliper and lever than the Guides. However, my research suggests the improvements to the B1 Code brakes would be similar.
    https://enduro-mtb.com/en/sram-code-2018-review/
  1. sram code rsc
    By sundace in forum Brake Time
    Last Post: 05-31-2018, 05:37 PM
  2. Sram code rsc
    By sundace in forum Downhill - Freeride
    Last Post: 05-30-2018, 08:27 PM
  3. SRAM CODE RSC Brake pads?
    By damdegraff in forum SRAM
    Last Post: 05-30-2018, 08:55 AM
  4. Hope T3E4 vs SRAM code RSC brakes
    By Dash8driver in forum General Discussion
    Last Post: 05-17-2018, 11:53 AM
  5. Code RSC Contact Point Adjustment Wheel Frozen
    By EricTheDood in forum Brake Time
    Last Post: 01-19-2018, 05:27 AM
Members who have read this thread: 65
