Results 1 to 2 of 2
    Wannabe Endurance Racer
    Reputation: Phknlwyr's Avatar
    SRAM 9.0 Disc Brake Question/Part
    I snapped the brake line at the banjo leading from the lever. I need to replace the line and the banjo nut. I know Goodridge makes a kit for this. Is anyone aware of any other parts/kits that would work for this application? My lines are gold in color. I am more concerned about their function, though, than their appearance. Thank you for your help!
    "The only time success comes before work is in the dictionary." - Vince Lombardi
    Reputation: Wombat's Avatar
    Quote Originally Posted by Phknlwyr
    I assume that you don't want the original hoses that you can get from here: http://www.bikeusa.com/MERCHANT2/mer...BrakePartsSRAM
    Alternatively you can probably use the old Shimano braided steel lines (M755s with banjos on both ends) that are also available from bikeusa.com.
    I guess that the Grimeca System 8 hoses will also fit. If you have your doubts take your levers to an LBS with the Shimano hoses and see if they fit.
    Wombat
  1. Replies: 2
    Last Post: 07-01-2004, 03:12 PM
  2. looking for for Sram 9.0 front disc adaptor?
    By rideit in forum Wheels and Tires
    Last Post: 06-02-2004, 06:32 PM
  3. looking for Sram 9.0 front disc adaptor?
    By rideit in forum General Discussion
    Last Post: 06-01-2004, 12:19 PM
  4. DOT 5.1 fluid with SRAM 9.0 disc brakes
    By jbadger in forum SRAM
    Last Post: 04-28-2004, 10:40 PM
  5. NE1 have a Sram 9.0 disc adaptor REAR?
    Last Post: 04-28-2004, 01:24 PM
