    Reputation: ol-crank's Avatar
    is squealing more likely the pads, or the disc
    I just put on a new set of the old Formula B4s and had my LBS bleed the brakes. The back is fine but the front squeals pretty bad. I took off the pads and sanded them, cleaned the disc with alcohol, wiped everything and same thing after about an hour on the bike. I do have extra pads, and an extra disc. Any suggestions?
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    you say you just put them on?
    give them a bit of time to bed in would be my suggestion...
    I can make my brakes squeal (i have to try) easier when the rotors are freshly cleaned (ie 'squeaky' clean)
    after some bed-in time some of the pad material or dust works into the micro-scratches on the rotor and should quiet down (at least I think )
    Honestly... ahh I give up
    Reputation: ToneyRiver's Avatar
    Let them wear in
    I agree just keep riding for a while and the brakes should break in and stop making noise.
    It's about showing up.
    Reputation: Berkeley Mike's Avatar
    Last time I looked at the back of Marta pads
    it said something like (paraphrase) take your bike up to top speed and brake hard to a stop 25 times.
    My wrench said to take it to the top of our steepest local hill, Marin Ave in Berkeley (about.5 mile at 19%), and ride the brakes all the way down.
    It worked.
