Results 1 to 11 of 11
    Jan 2005
    New question here. Splined rotors... Shimano vs. Avid... Compatability?
    I'm new to disc brakes. I've just received a brand new bike from an online dealer with Avid mech 5's and XT rotors. Should there be a compatability issue here? My LBS noticed that the Avid pads' surfaces are bigger than the XT rotors' braking surfaces. This is the way my bike (which I purchased from a pre-existing online build sheet) was spec'd from the online shop, and I have experienced pulsing with my rear brake. The new XT hubs require the XT or XTR splined rotor vs. normal 6-bolt, which apparently limits rotor selection to Shimano. Anyone else have experience with this? Are there other splined rotors out there that would be compatable with my Avid mech if the XT's aren't?
    I liked the simplicity of the mech brake, and the rave reviews of the Avid mech sold me. However, I'm not entirely convinced that they're compatable with the XT rotor with performance thus far. I wish I knew about the splined hub thing before purchasing the bike spec'd the way it was. I'm thinking about selling my Avid mech setup (SD-7 levers, flack jacket cables, and Avid mech 5 calipers) and investing in XT or XTR hydros for piece of mind. Are there other caliper options (mech OR hydro aside from Shimano) that would be compatable with my splined XT hubs and XT rotors?
    Can anyone recommend a lightweight and relatively hassle-free brake setup that would allow me to keep my wheels "as is"? I'm getting my hands more dirty with my bike every day, but I'm not a trained mechanic. I have an inherent fear of a hydro line braking on me on an epic ride...thus my interest in mechs.
    Any help would be greatly appreciated!!!
    Thanks.
    Reputation: shiggy's Avatar
    Dec 1998
    The pulsing is probably from the pads grabbing the rotor arms.
    You can get centerlock to 6 bolt rotor adaptors. I would call the place you bought the bike and ask them to exchange your rotors.
    mtbtires.com
    Jan 2005
    One problem...
    I had a hard enough time getting my bike to my doorstep. Now, I'm going to finish this deal either with my LBS or another online shop. Exchanging with the original online shop is pretty much out-of-the-question. Where can I find those adapters?
    Thanks again.
    BAR
    BAR is offline
    Dec 2004
    The XTR rotor will fit XT hubs but that might not fix your problem. Jenson sells an adapter that may help.
    http://www.jensonusa.com/store/product.aspx?i=BR605Z00
    Jan 2005
    Additional requirements?
    Using said adapter, would I need a spacer or adapter to adjust the alignment of the rotor with the caliper? I would think that the adapter would move my rotor outwards by a good 1/8" or more. Thanks.
    ride
    Reputation: ignazjr's Avatar
    Quote Originally Posted by shiggy
    It is. I ran XT rotors with Juicy 7s for a bit to see if it'd work. They worked fine, but had a slight pulsing problem. I dremmeled them (same fix as the pulsing Juicy's) and that worked out.
    Still, though, I would go with the IS 6 bolt adapter and get some Avid rotors. More braking surface = more braking power.
    Redstone Cyclery
    intense*transition*rocky mountain*turner
    web - tweet - FB
    Lyons, CO
    Dec 1998
    That's the one. Your LBS can order it from QBP.
    mtbtires.com
    Dec 1998
    Nope. Designed to work as-is. I would recommend Galfer rotors BTW. Longer pad life and better in the wet than the Avids
    mtbtires.com
    Jan 2005
    Options
    I guess one option then is to purchase 2 adaptors and 2 rotors. I probably need new pads too, since the rotor arms most likely caused uneven wear on the current pads. At best, this comes out to $116.
    Option 2 would be to purchase 2 adaptors and 2 Avid Ball Bearing 7 brakes (upgrade), which come with calipers, rotors, and pads. At Cambria, I can dig up a price of $178.
    Is the $62 difference justifiable by the added features of the Avid BB7 vs. Avid BB5? I couldn't find weight characteristics. Anyone know 'em?
    Also, has anyone used these splined-to-6-bolt adaptors? I'm 185lbs and slightly worried about compromising the strentgh of my bike's braking hardware.
    Still like the idea of mechs...
    hands up who wants to die
    Reputation: rpet's Avatar
    You can get Avid BB7s cheaper, probably from Jensonusa.com and ebay. Other places too.
    I think the new BB5s offer less pad adjustments, and would therefore make set-up and ongoing adjustment less fool-proof. Read the reviews and see what you think.
    All disc brakes are relatively heavy, and I believe Avid's are some of the heavier ones out there (depending on brake lever choice: I'm talking complete brake system weight (lever, cable, rotor, caliper). I don't think there will be any significant weight different between BB5 & BB7, if that's what you're asking.
    -rob in NY
    Dec 1998
    I would avoid the BB5 for adjustment reasons.
    mtbtires.com
  1. Up-sizing Shimano XT rotors to 180 or 200 mm
    By Dave99 in forum Brake Time
    Last Post: 09-22-2004, 11:36 AM
  2. Replies: 3
    Last Post: 07-01-2004, 11:36 AM
  3. Shimano XT hydros vs. Avid mechs
    By matt719 in forum Brake Time
    Last Post: 06-22-2004, 01:01 PM
  4. hayes 8" rotors with avid mechanicals
    By Duncan in forum Brake Time
    Last Post: 05-04-2004, 06:43 AM
  5. Help w/ replacement rotors for Avid Mechs
    By ThornPatch in forum Brake Time
    Last Post: 02-03-2004, 02:23 PM
