Results 1 to 7 of 7
    Speed dial 7 adjustability
    Does anyone know if these levers can be adjusted such that they would be suitable for caliper and cantilever brakes?
    Yo.
    Reputation: Slow Eddie's Avatar
    if you mean road caliper and center-pull cantilever brakes, no.
    If you mean disc caliper and linear-pull cantilever brakes, yes.
    Quote Originally Posted by JonathanGennick View Post
    I am a poser. But forums.poser.com doesn't seem to exist, so I come here instead.
    I was hoping that the levers would work for road caliper brakes when the levers were adjusted so that the cable attachment point was closest to the lever pivot point. I wanted to buy the levers for my current commuter and later transfer them to a mountain bike I'm building up. I guess that won't work then....
    LDH
    LDH is offline
    Reputation: LDH's Avatar
    I ran some sd5 levers with my side pull road brakes, they worked but not super strong until I scored some tektro bmx levers on ebay which work great.
    http://cgi.ebay.com/New-Tektro-BMX-C...3286.m20.l1116
    Former Bike Wrench
    Get the Tektro RT354 levers...problem solved
    Never trust a fart
    Reputation: frdfandc's Avatar
    Actually the SD7 levers work quite well with center pull cantilevers. They also work well with the BMX style brake caliper too.
    I just pulled a set off my old hardtail with the above mentioned brake setup.
    On the more technical/geeky side, does anyone know the approximate range of mechanical advantages to which the SD7s can be set? I can't seem to find this information anywhere online. The Avid website is next to useless.
    Apparently, a lever mechanical advantage of ~2 is appropriate for V-brakes, while a mechanical advantage of ~4 is appropriate for (road) caliper brakes.
