Results 1 to 18 of 18
    Reputation: Trackho's Avatar
    Sintered pads for 2012 XT M785s- where??
    Need to buy better pads--can't find the sintered with the fins anywhere Anybody
    have ideas??? I'm guessing you only need to buy the fins once--I hope
    Here. I know they say they are for XTR brakes, but if you look at the Shimano tech docs they both use the same pads.
    Quote Originally Posted by dlporter View Post
    Thanks just ordered cheap shipping and no tax ---cool beans-thanks
    Does anyone know if you need to keep buying the heat sinks??? Or can you buy just the pads for less???
    the OEM XT brakes i bought did not come w/ finned pads, so I would say they are not necessary. The 30.00 sintered do not last twice as long as the 15.00 resin in my experience. Both work well, but i run through pads quickly in dry So. Cal.
    Quote Originally Posted by rjedoaks View Post
    Its something to pay attention to when buying the 2012 XTs, at Tree fort they give you sintered pads with the fins--which cost about $40 per end, compared to approx $20/end for the Resin/finless pads that you get at BlueSky.
    Personally, I cant stand the feel of Resin pads, so has to be metallic sintered pads. The fins are cool, just seems like you should only have to buy them once, but I was wondering if the pads were slightly thinner to accomodate the fin "back plates"
    Ho'lier than thou
    Reputation: Katz's Avatar
    Quote Originally Posted by Trackho View Post
    ...Personally, I cant stand the feel of Resin pads, so has to be metallic sintered pads...
    Would you mind updating later how the sintered pads feel, specifically modulation, once you have a chance to ride with them?
    I just got M785s for my bike with resin pads. I'm happy with the stopping power, but would like a little more modulation.
    I found out, after searching the forum, many say organic pads have better modulation but some say otherwise. And I've run metallic race pads on my car that offered better modulation than Autozone-special organic pads. I guess not all metallic pads are created equal, so I'd like to know how these particular Shimano pads feel.
    I'd appreciate your input.
    Quote Originally Posted by Katz View Post
    Will do, I come from a motorcycle road racing background where Vesrah sintered pads rocked, all else pales in comparison, I'm guessing the sintered shimanos will be similar, the sintered avid pads were noticably better than
    resin.
    I weigh 225 and like to go fast, so I'll be a good test point
    I use the resin up front because I could not stop the howling at a certain point w/ the sin. Sintered in the rear, mostly because they wear longer. They both work well IMO. I definitely don't feel a drastic difference between the two.
    The fins are part of the backing , not separate, if that was your question.
    The shops charge 15 for resin/ 30 ti back Sin/ 40 Finned. 40.00 is a little steep for brakes. I'm going to try the Swiss Stop next.
    Shimano pads wear quickly, but Im 235.
    Mar 2012
    edit: misunderstood
    Ho'lier than thou
    ...I come from a motorcycle road racing background...
    I see where your user name came from. I have utmost respect for you motorcycle road racers Getting rear end come around in my 130-hp car at Willow Springs T9 is scary enough for me LOL.
    Heres the carasoul at Infineon--prolly going about 90mph, then at the bottom you get on the gas, hit about 130mph, then HARD on the brakes going into T7, usually the rear tire is off the ground (don't use rear brakes much in road racing), then a light trail to the apex. All good fun
    Attached Thumbnails Attached Thumbnails Sintered pads for 2012  XT M785s- where??-carasoul-medium-.jpg
    Ho'lier than thou
    Awesome picture!! I just can't imagine what it's like to lean the bike that much at the limit of adhesion
    Just got the sintered pads from universalcycles.com--they were super quick, no sales tax, $2.99 shipping and a chocolate too boot--Im very impressed--they were about $37 each shipped
    Like others had said the heatsink is part of the backing plate, unfortunately I wont be able to test them for a week--going skiing, but when I get back Ill give an update
    Suspension Specialist
    Nov 2012
    I have spent my whole life in the motorcycle industry, and Vesrah has had the absolute best brakes you can buy for a over a decade.
    They have a full line of pads for the most common bicycle calipers, and my best friend is the US importer. He's setting me up to distribute their pads.
    They have several compounds, from oem replacement type, to XC to Downhill.
    I am running their XC compound (with trick aluminum backing plates) on my 2013 Stumpjumper, and they are awesome on the Avid Elixir brakes. The stock pads squealed and made enough racket to make you think you were going to crash. Plus they always felt like metal on metal... no grip, no feel, no feedback, until the locked up!
    The Vesrah's are just the opposite. And since they have a smooth linear force curve, you can actually get more outright stopping power before lockup. I am meeting with my friend next week to map out a plan to be able to make them available as soon as possible.
    Helmetless Crasher
    Reputation: Stumpjumpy's Avatar
    MB Action Mag has a good comparison review of the pads.
    Basically, they prefer the Resin pads because of their great feel/modulation.
    I've tried both compounds on my 785 XT's, and I agree with their assessment.
    '95 M2 StumpJumper FS
    '11 Cannondale RZ 120-two
    Nov 2012
    Quote Originally Posted by Stumpjumpy View Post
    What year/month was that review, do you recall?
    Nice avatar.
    Helmetless Crasher
    Sep 2012
    I'm on the other side.. Ran the metallics liked them except for the squealing..so I put resin pads on and they just felt like mush/soft..plus I went through a set super fast(within a few rides)..now I'm back to metallics and like the feel way more..just put some ice tech rotors on in hopes of silence..time will tell..
