Results 1 to 2 of 2
    Should I bleed both my brakes at the same time?
    I am taking my bike to the shop b/c my front elixer stopped working. It just pulls all the way to the handlebar. The right works fine. Is there anything wrong with having them bleed the front brake, but not the back? The back works fine, and I would like to save a little money.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    There's nothing that says you need to bleed them at the same time. If it's working that's about as much as you can expect out of a brake. It's also worth mentioning that you should be bleeding your brakes once in a while anyway, to keep them running well. You don't to bleed them at the same time, but there's probably a reason your front needs to be bled and I would recommend doing the rear should be bled at some point as well.
  1. Time to bleed Avid brakes?
    By rustbucket in forum Brake Time
    Last Post: 04-29-2010, 06:25 PM
  2. first time bleed?
    By tmonck in forum Brake Time
    Last Post: 11-29-2008, 05:47 PM
  3. time for a bleed?
    By jonwebah in forum Brake Time
    Last Post: 05-30-2006, 08:39 AM
  4. How do I bleed my brakes?
    By MTB-AHOLIC in forum Brake Time
    Last Post: 11-04-2005, 09:34 PM
  5. Time to bleed?
    By jixdog in forum Brake Time
    Last Post: 08-05-2005, 10:03 AM
