Results 1 to 8 of 8
    Reputation: fixbikeguy's Avatar
    What fork are you running? Some are pretty flexy and can cause the wheel to move over under hard braking.
    Expert Noob
    Reputation: LandoCommando's Avatar
    Should this happen if the rotor is centered?
    When my front brake grabs the rotor I can visibly see the whole wheel move to the side with the braking.
    Everything is tight and I have J3s. Is the rotor not centered?
    Expert Noob
    Quote Originally Posted by fixbikeguy
    DJ 2
    Reputation: vk45de's Avatar
    The total lateral force on an off centered shouldn't be anything compared to the braking load which should be pretty much the same in either case so it can't be caused by off center rotor. Perhaps you can describe it in a little more detail
    - Setup - hub, lacing pattern
    - Motion - sliding or tilting
    Expert Noob
    Quote Originally Posted by vk45de
    The top of the wheel tilts to the side the rotor is on
    Reputation: sanjuro's Avatar
    Sep 2004
    How about the easy answer: loose hub bearings...
    I was leaning towards sanjuro's conclusion too. Are you sure everything is tight?
    Never enough time to ride
    Reputation: squish's Avatar
    Sounds very much like loose hub bearings...can't think of anything else it could be, unless the through axle is loose in the fork.
    happy trails...
    squish
    Get out and ride!
