Page 5 of 5 FirstFirst 1 2 3 4 5
Results 101 to 120 of 120
  1. #101
    Quote Originally Posted by hokiebrett View Post
    Just did my XT's tonight. The original link was bad and didn't see the updated link until now.
    For anyone wondering if you can do this... I did front & rear in a hotel room. No stand, no vise, no vise grips. With the calipers on the bike (pads out)
    Just some Allen wrenches, tire levers, small Channel Locks, Crescent wrench and a utility knife with a fresh blade (simply cut the hose while it was laid horizontal on a table).
    Still need to pop the reservoir cap on the front brake, it's really stiff/firm.
    Followed similar (same?) procedure.
    Shorten Shimano Brake Hoses without Bleeding | Epic Bleed Solutions
    Impressive! How did you pound that thing into the line without v grips?
  2. #102
    Rocks belong
    Quote Originally Posted by cjsb View Post
    Banged it against the desk My brakes did come with the yellow clamp block, but I could've made due without it.
    Just lightly loosened (1/4-1/2 turn) the reservoir caps. A small squirt of mineral oil came out of each (on its own). Tightened back up and now my brakes are good to go!
  3. #103
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Another success story
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  4. #104
    Apr 2014
    I'm reading the how-to on Shorten Shimano Brake Hoses without Bleeding | Epic Bleed Solutions and got one question about this:
    Reset the calliper pistons by pushing them apart with your plastic tyre lever or similar tool. This will ensure that any air which may have entered the system will be pushed into the master cylinder.
    So in the end is the air going to be kept in the master cylinder or it should be released somehow?
  5. #105
    Magically Delicious
    The air is forced into the reservoir by pressing brake caliper pucks back into the caliper. You then just top off the reservoir, seal 'er up and go ride.
  6. #106
    Apr 2014
    Quote Originally Posted by Cleared2land View Post
    It's interesting that there's no mention about topping off the reservoir in the guide. Or I'm missing something here. Sorry, English is not my native language.
  7. #107
    Magically Delicious
    Quote Originally Posted by AeroZ View Post
    Actually, you probably don't not need to top off the reservoir. By pressing the puck back into the caliper, you should have displaced any remaining air and thus refilled the reservoir. The whole purpose of expanding the brake pucks. Perhaps I should have said "check that your reservoir is topped" and go ride. It's just an accepted practice if you've done anything that affects your fluids to check or top off the reservoir.
  8. #108
    Apr 2014
    So if you move the air into the master cylinder by resetting the pistons then from this point on you should not turn the bike upside down or the air goes back into the hose?
  9. #109
    Magically Delicious
    While you are pressing the brake pucks back into the caliper, you have the bleed port opened on the top of the master cylinder reservoir cap (which must be positioned level in order to allow all remaining air to escape). All of the remaining air will (or should) exit the reservoir cap bleed port. If you have pressed the pucks back in and you still have remaining air in the reservoir, then you will need to top off the reservoir thus eliminating any remaining air. Normally pushing the pucks back in performs the function of topping off the reservoir, but if not, then top it off. With no air remaining, you can turn the bike in any position and it won't matter.
  10. #110
    +1
    Sent from my SM-N900T using Tapatalk
  11. #111
    Man, it's late, but just finished another one, this time I got the hose length down just right, but that vice grip was pita, finally remembered to wedge the blocks into the vice grips, like a diamond shape and then it hammered home!
  12. #112
    Magically Delicious
    Measure twice, cut once.
  13. #113
    Moosehead
    Reputation: moosehead's Avatar
    Slightly OT, I'm getting very slight oil leakage where the hose enters the lever. Is the best bet to recut a bit of cable and install new plunger and olive, or just retighten the existing setup? In either case, I'm to ADD to just let it slide on a front brake.
  14. #114
    Magically Delicious
    Quote Originally Posted by moosehead View Post
    Probably no need to re-cut and install new olive and insert, just tighten up the line nut. I originally had some minor leakage when I shortened the hoses and incrementally tightened until seepage stopped. Technically these line nuts have a specified torque, but you need a Crows Foot and perform the torque calculations to do it properly. I have just used the 'calibrated wrist' technique and gotten by.
  15. #115
    Apr 2014
    I shortened my Shimano M615 hoses and bleed them just in case too. Now when I press the lever I hear some slurping noises or something similar under the reservoir cap. Is that normal? I don't remember if the levers made that funny sound before.
  16. #116
    Magically Delicious
    Nope, not normal. You introduced air some how and didn't get the air out. Sounds like some air might remain in the master cylinder piston. Did you expand the brake pucks, cut and re-install the brake lines and press pucks back in? Possible by bleeding (top down?) you might have just pushed what little air remained at the master cylinder reservoir down the line.
  17. #117
    Apr 2014
    I removed the pads again, opened the reservoir cap and pushed the pistons in. A bit of oil came out of the reservoir. Put everything back together and it's still making the sound. It's really quiet tho - I have to put my ear next to the master cylinder to hear it. Rear brake makes less noise under the reservoir cap tho. Both levers seem to be stiff. Both reservoir caps seem to be nice and tight too.
    I also checked under the reservoir cap while it was off. The oil level decreased and increased while operating the lever. It still made that sound. Maybe it's the lever mechanism under the reservoir cap that's making it?
    Anybody else hearing noises from their Shimano (M615 or similar) levers when operating?
  18. #118
    Feb 2010
    Just finished shortening my XT hoses using the no bleed method and everything went to plan. Another success story. Super simple to do.
  19. #119
    Jun 2012
    I just bought a set of M785's and they are right front/left rear which is opposite of all my other bikes, would it make a difference if I swapped the hoses when I go to shorten the hoses ie: make the right rear/left front as the same as my other bikes.
    the levers are the same on both sides correct? figure it wont matter ?
    doug
  20. #120
    Magically Delicious
    Quote Originally Posted by stingray230sx View Post
    the levers are the same on both sides correct? figure it wont matter?
    When you shorten the hose you can do the swap. Plenty of threads here to help with that.
    After many years on motorcycles I could never get used to the Front Brake being on the Left, so I have always run my Front Brake on the Right. It's common to see this configuration in Europe.
