    Shortening Juicy 3 hose?
    Yeah, I know they are not great, but I'm going to keep them until the pads wear out. However, the front hose came really long, and it rubs all over the place as it winds back and forth down to the caliper. Can this be easily cut, reconnected and bled, or are they factory set only?
    Never trust a fart
    Reputation: frdfandc's Avatar
    You can shorten the hoses, but make sure to get new compression fittings and a bleed kit. If not, then the hose will leak and you will be pulling you hair out trying to bleed the brake.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    If your really sneaky you can shorten the hose and reconnect without bleeding but you should be prepared to bleed just in case.
    Formotion Products
    http://www.formot
    Quote Originally Posted by dogonfr
    I shortened my Juicy 3's hoses and needed to rebleed the system.
