Results 1 to 3 of 3
    CC
    Shortening a Goodridge brake hose
    I have brakes with Goodridge hoses and would like the shorten the front cable....
    2 questions:
    1.) what do i use to cut the steel line.....?
    2.) are all of the connections reusable once i take them off.....?
    I know with my old Hayes brakes whenever i disassemble i have to replaced a small fitting....
    I used a park tool cable/housing cutter. You will also need to strip back the plastic sheathing 11 mm before reassemby.
    Yes all fittings are reusable.
    It's a very easy job to do.
    CC
    Thanks....i thought i knew the answers but was only 85% sure.........didn;t want to get stuck without a bike to ride.
