Results 1 to 5 of 5
    Reputation: noosa2's Avatar
    shims = little washers?
    I just picked up a set of Shimano deore M555 brakes and they did not come with any shims (or mounting instructions) to use when mounting the brakes to the frame and fork. I found this installation sheet that refers to the shims:
    http://techdocs.shimano.com/media/te...9830604555.pdf
    Are the shims just little washers?
    ...idios...
    Reputation: SteveUK's Avatar
    They are, yes. Here are the Hope sizes. You can get them from your LBS or even a hardware store, but bear in mind that ((sometimes) cheaper hardware store one's may not be consistent in their size.
    Diogenes
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by SteveUK
    True, and hardware store washers are much thicker than shims.
    mtbtires.com
    LA CHÈVRE
    Reputation: Dan Gerous's Avatar
    In the Ghetto, they make DIY shims by cutting some off Coke cans...
    DAN.GEROUS.NET : MOUNTAIN BIKING : CYCLOCROSS : ROAD :
    Meh.
    Reputation: XSL_WiLL's Avatar
    What they all said.
