    Hoser
    Reputation: BC Bomber's Avatar
    Mar 2011
    Shimano zee rotors
    I'm running shimano zee brakes with avid hs1 rotors which are 200mm. The shimano rotors are 203mm, am I screwing myself by not running 203mm rotors? Also my rear mount adapter is 203mm.
    And would it be an upgrade going from the hs1 to these?
    Shimano XT-Saint RT86 Ice-Tech 6-Bolt Disc Rotor | Chain Reaction Cycles
    Do you know what 3mm looks like?
    Hunduh
    Hoser
    Mar 2011
    3mm looks like quite a bit, when your braking surface is like 14mm...
    any thoughts on the ice tech rotors vs hs1?
    The Ice Tech rotors are better. Nicer metal IMO, and better heat dissipation. I also think they look better but whateves.
    As far as the difference in size, no, you won't really notice the diff. Friction is dependant only on the force and the coefficient of friction for the surfaces, the area of contact doesn't really matter as much. That's one reason why the large cutouts in brake rotors don't produce much of a variable braking force.
    I don't know whether the shimano rotors are just 3mm larger in diameter with about the same braking track width, or if they also have 1.5mm wider braking tracks. Like I said however, it doesn't matter.
  1. Which rotors with Shimano Zee?
    By BTTR in forum Brake Time
    Last Post: 11-24-2014, 03:19 PM
  2. Shimano Ice-Tech rotors with Non Shimano system?
    By Buggyr333 in forum Brake Time
    Last Post: 11-18-2012, 11:07 PM
  3. shimano brakes - do I need shimano rotors?
    By Gabe3 in forum Brake Time
    Last Post: 03-15-2012, 07:15 PM
  4. Shimano RT-76 Rotors
    By BaeckerX1 in forum Where are the Best Deals?
    Last Post: 05-26-2011, 03:10 PM
  5. Anyone tried Shimano ICE rotors yet?
    By gticlay in forum Brake Time
    Last Post: 03-01-2011, 08:08 PM
