Results 1 to 7 of 7
    Feb 2012
    Shimano XTR Race vs XTR Trail pad clearance
    Hi folks, Iīm really fed up with my Formula R1 constant rotor rubbing so Iīm looking for some replacement.
    Shimano brakes in general have the "fit and fotget" reputation and thatīs exactly what Iīm looking for.
    Iīd just like to know, if there is any significant difference between pad clearance of XTR Race and XTR Trail.
    Based on what I have seen and tried at my LBS, Trails pad clearance is really generous, Race model seems to be noticeably tighter (probably due to absence of Servo Wave lever) but thatīs all on new bikes with pads not burnished.
    Is there anyone with real world experience, ideally riding both Race and Trail models?
    Iīm more after the Race model, as I donīt need either tool-less reach adjustment or Free Stroke adjustment (what I have heard does almost nothing anyway) Plus, I really like their smooth lever feel.
    But if the pad clearance is significantly better on Trail model, I would probably take those, cause I dontīt really want to spend hours in garage adjusting the calipers again.
    Or the other (and maybe the most "rational") option would be saving some money and buying SLX, which should have the same power, but they come at much heavier package and I donīt like their design too...
    Thanks for any help!
    I'm just messing with you
    Reputation: wv_bob's Avatar
    If the race and trail setups use the same calipers then there would be no difference in the pad clearance.
    FWIW, rubbing pads drive me nuts too.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Comparing my XTR Trails to my Formula Megas, the Shimanos are far easier to run rub free. I don't know about newer Formulas however but if I remember correctly clearance was even worse on fhe new gen.
    Check out my SportTracks plugins for some training aid software.
    Jun 2012
    I thought that was one of the improvements on the 2013 formula brakes, increased pad clearance.
    Feb 2012
    You are right, all 2013 Formulas should have more pad clearance. They call it ECT - Enhanced Caliper Technology and it definitely is a major improvement for their 2013 lineup (although I donīt know anyone riding them, but they have pretty positive references on some german forum), but my R1s happen to be MY2012 so their pad clearance is really tight and their power is also not much good.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    Its my understanding that there isnt anything different between the Calipers. The trail version has finned pads and heavier levers. I have m975 XTR brakes and they never rub.
    g3h6o3
    Oct 2007
    I did not know about improvements for 2013, I was referring to the Oro vs. newer design!
    Quote Originally Posted by Learux View Post
  1. Shimano M980 Double clearance issues.
    By SandmanLJS in forum Frame Building
    Last Post: 05-22-2013, 07:55 PM
  2. XTR vs. Hope Evo X2 Race pad clearance
    By Andy13 in forum Brake Time
    Last Post: 05-09-2012, 08:48 PM
  3. Shimano XTR m988 wheelset clearance
    By mtblol in forum Wheels and Tires
    Last Post: 04-27-2012, 09:48 PM
  4. Shimano Frame Clearance Checking tool for M980/M985
    By Cheers! in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-03-2012, 06:36 AM
  5. Shimano XTR Race vs Trail
    By bikerboyj17 in forum Brake Time
    Last Post: 07-26-2011, 11:57 PM
