    Sep 2004
    Shimano XT Rear Brake Lever Soft
    I have a what may be a 2009 Shimano XT disc brake lever set. I do not get to ride often.
    My rear brake lever is soft on the first pull. It squeezes all the way in on the first try.
    If I pull multiple times it gets firmer.
    Is it a brake pad issue, a need for more fluid or air in the lines?
    Any quick fixes? Thank you
    Reputation: 11053's Avatar
    You need a brake bleed
    Sep 2004
    Thank you.
    B A N N E D
    Quote Originally Posted by JediSith View Post
    Air is a bad thing to have in hydraulic brakes.
  1. How do you adjust the brake lever on Shimano XT bakres?
    By mrmojorising8 in forum All Mountain
    Last Post: 08-26-2015, 07:28 PM
  2. Shimano brake lever blades.
    By plugp7 in forum Brake Time
    Last Post: 11-05-2013, 09:55 AM
  3. Replies: 6
    Last Post: 12-20-2012, 10:29 AM
  4. Replies: 11
    Last Post: 11-13-2012, 06:27 AM
  5. Shimano brake lever adjustment
    By scalla in forum Brake Time
    Last Post: 01-25-2012, 08:20 PM
