Results 1 to 6 of 6
    Apr 2013
    Shimano xt popping sound on lever
    Each time I squeeze the front brake and let go a popping sound happens. Is there a way to fix this or will lubing help? My concern is using lube and dirt gets into the lever.
    Thank you
    I had this same issue and I asked about it a week or so ago. My 785b brakes are new and the sound has gone away from use on a short ride. I am assuming yours are new too or at least I hope so. Just use them and hopefully it will go away as mine did.
    Mar 2013
    Lubricating the pivots is a good idea. XT and XTR trail have a servo wave mechanism and that might be your pop. Lube that too with a light oil. Oil there won't get inside the hydraulic system.
    Apr 2013
    Quote Originally Posted by ace42 View Post
    Pretty new I would say, I got them back in May or June? Only the front brakes do it. It's odd... hopefully using it more would fix the popping sound.
    Apr 2013
    Quote Originally Posted by someoldfart View Post
    I have a parktool lube that I use for my rear derailleur.... would that be a good to use? Where the lever goes into the brake system... is where I put some lube. I noticed a steel cylinder which moves each time you pull the lever. I added some oil there, but still the popping sound appears. Any ideas?
    Apr 2013
    By the way, thanks for the replies
  1. Replies: 7
    Last Post: 03-20-2013, 06:47 AM
  2. Formula RX lever squash sound
    By polarflux in forum Brake Time
    Last Post: 09-28-2012, 08:00 PM
  3. Popping sound from tire
    By ubermustang in forum Wheels and Tires
    Last Post: 07-25-2012, 07:00 AM
  4. Popping sound after installing new chain
    By Mookie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-11-2011, 12:31 PM
  5. DHX propedal stiction and popping sound. Anyone else?
    By tscheezy in forum Shocks and Suspension
    Last Post: 09-14-2011, 03:48 PM
