Results 1 to 14 of 14
    Reputation: Epic_Dude's Avatar
    May 2010
    Shimano XT - Pad Rattle - Normal?
    After installing my new M785 XT Brakes I noticed a rattle sound that seems to be the pads rattling in the caliper when I'm riding fast on a bumpy downhill and not applying pressure to the levers. Anyone else notice this? Do I need to bend the pad springs out a bit?
    Reputation: Niner_Boy's Avatar
    Sep 2012
    Nah...just get a small elastic band and wrap it around the fins (not fin to fin, but one elastic band per fin). If you can source black elastic bands from inner tubes, you won't even notice them. This is a common fix and should get rid of the rattle.
    Current Stable: 2011 Niner EMD, 2011 Vassago Jabba
    May 2010
    Ted
    Ted is offline
    Ted in real life
    Reputation: Ted's Avatar
    I am not loving the same issue. I tried the rubber bands made from inner tubes and it helped a bit but the problem was still there. Any other fixes?
    Reputation: AZ Stumpy's Avatar
    Nov 2008
    My SLX's did that too. Switched to normal non-finned pads and no problems since (with rattling or brake fade).
    nothing to see here
    Reputation: Stevob's Avatar
    Non-finned pads fixes the problem. XT here.
    I see hills.
    I want to climb them.
    Nov 2008
    Anybody ever notice when holding down on the brake, the bike rocks forward and back. It was pretty noticeable on the my front brake. I thought I had a lose headset but its actually the brakes. When you clamp on the lever and rock the bike, you can see the pads moving.
    Reputation: jkirkpatri's Avatar
    Quote Originally Posted by mmanuel09 View Post
    Yes, the pads move quite a bit, IMO. I too thought I had a loose headset, they move that much. Now that I know what's going on, I'm not that concerned about it. I'll probably opt for the non-finned pads when my existing pads are due for replacement.
    A lot of disc brakes do this. You'll notice that if you apply more pressure, there is enough friction between the pad and piston and they stop sliding around in the caliper. So squeeze harder when you're actually trying to check your headset.
    Yes, I noticed the rattling noise as well when I installed my brakes. I bent the pad springs a little but now I think I've just gotten used to it. Just a consequence of having the fins on there to dissipate heat. Which IMO is more important than a little rattle.
    Don't think there's really much of a way to solve it.
    Aug 2013
    My XTs do not move on a downhill, they work great with very little fading on long descents. Is it really much better with finned pads?
    Quote Originally Posted by Ted View Post
    I noticed this immediately on my Saint breaks, I really don't understand how the pro's who ride this equipment would stand for this.
    I took an old inner tube and cut a section about 3mm wide with scissors. I then wound it between the fins from top to bottom then around the backside of the fin surface. This provides a rubber bumper between the caliper and the pads that has completely stopped the noise. Visually you cant see it and it has not moved or broken at all. It also allows the pads to move freely.
    Stupid you have to go through this to have a silent bike really.......but it works.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    The Saints on my DH bike have gotten noisy with the rattle. Sort of rattles me when concentrating on the trail. Thanks for the ideas on the fix.
    Edit....
    Just pulled the pads and noticed quite a bit of wear. Maybe the diminished pad size allows less tension on the spring and more wiggle room. Perhaps its sort of a built in alarm system by Shimano letting you know its time to replace the pads. I stretched the spring out a bit to apply more tension. Will also pay attention if replacing with new pads helps.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Quote Originally Posted by Miker J View Post
    ...Just pulled the pads and noticed quite a bit of wear. Maybe the diminished pad size allows less tension on the spring and more wiggle room.....
    The gap between the pad surface and rotor stays more or less constant since the pistons advance to adjust for pad wear. With worn pads, the pistons and backing plates are closer together, so spring tension would be greater, all else being equal.
    Do the math.
    Reputation: Mr Pig's Avatar
    You can help it by bending the pad spring so that the fingers sit more parallel than in the 'V' shape they sit in as standard. I also find that the noise goes away once the brakes collect s bit of dirt, as long as you don't clean them again ;0)
  1. Fox 32 F-Series RL rattle
    By Bsktball55 in forum Shocks and Suspension
    Last Post: 07-27-2013, 06:25 AM
  2. A list of Shimano XT and XTR low/normal/non rapid rise compatible rear derailleurs.
    By GottaGo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-19-2012, 08:45 AM
  3. Replies: 3
    Last Post: 08-17-2012, 02:09 AM
  4. Marz 44 rattle
    By DiRt DeViL in forum Shocks and Suspension
    Last Post: 09-26-2011, 10:54 AM
  5. Fox F29 RL - rattle at top out?
    By Vermont29er in forum 29er Bikes
    Last Post: 07-26-2011, 07:06 AM
Members who have read this thread: 17
