Results 1 to 3 of 3
    Aug 2013
    Shimano XT M785 caliper with an XTR M988 lever?
    Need some help guys... I want to set up 2012 m785 calipers with xtr m988 levers, any advise... I been told that I would need the xtr hose bh90.
    Is anyone runing this set up ? or similar ??? all help and info would be fantastic !
    calipers and levers are new model brakes 2012.
    Need alll the help I can get.
    On your left.
    I've read of mixing Shimano brake parts (i.e. Saint & XTR) - my question is why? Saving cost or weight? Don't like servowave? Performance?
    Anyway, the Shimano site gives detailed parts lists, so that should answer the OPs question.
    M
    Aug 2013
    Hi !
    Is that I got a pair of new 2012 xt calipers... and just recently purchased only the levers xtr m988 , Im trring to keep cost as low as possible for now...
    been told that the xt caliper is a OK caliper... not a xtr but Ok.. Im not concern on weight saving goes...
    Have you done this set up ? would you know if it will work ?
    thanks in advance !
  1. M775 Caliper compatible with M785 Brake Lever ?
    By Goran_injo in forum Brake Time
    Last Post: 09-24-2013, 05:24 AM
  2. Replies: 12
    Last Post: 08-19-2013, 10:33 AM
  3. Shimano XTR M988 brakes XT Caliper
    By Tyson2007 in forum All Mountain
    Last Post: 08-15-2013, 01:44 AM
  4. Aligning caliper to disc (Shimano M988)
    By jizzim in forum Brake Time
    Last Post: 04-22-2013, 12:12 AM
  5. Shimano M775 caliper with M988 lever
    By gnarly in forum Brake Time
    Last Post: 12-02-2012, 09:17 AM
